go to the shop and read the back of each oil. only look at the ones with the prices you would like to pay. buy something that fits the way you feel about your car. thats what i do.. either mobile 1 magnatec or last time i used something else which i cant remember ahhaahhaha
Guest Boxhead
motul 8100? i didnt see that one, ohwell
i use motul 6100, its like $4 cheaper then mobil one at the auto barn i was at, and $10 cheaper then the castrol formula r, i just put it in last nite, and i think the car is smoother then the other stuff in it from compliance...
but motul has a way better cap thing on it, you can pull it out and so its much easier to pour :)
Where can you buy good quality oil from in 20L drums? That is the cheapest way to buy it apparently.
Edit: Erm, not "the" cheapest, obviously, but probably the cheapest while still remaining somewhat practical.
I bought some motul 8100 because I was too lazy to drive further from home in search of (cheaper) mobil 1. besides which, the mobil 1 I had in the car broke down quite suddenly at around 7500km since being changed. that kind of end-of-life knee worries me, it's too quick. I guess you REALLY know when the oil's had enough though.. "holy christ it's below the low mark and it's turned really dark!" (previous checks had all shown very little oil usage and still light golden colour)
hmmmmmmmmmmm..... :O
Castrol R synthetic is an excellent oil. Pricey but im a great believer in you get what you pay for. If your engine hasnt been using synthetic oil previously you will find that for the first 5 to 10,000kms you will burn oil. This is because your bedding in the bores to suit synthetic oil.
Try Tufoil additive. Its in the guiness book of records as the slipperiest oil additive in the world. They ran an engine that had the oil drained containing Tufoil and it ran 8 times longer than the second longest engine with i think Slick 50 added to it. My engine still looks brand new inside.
Michael...
Changing the oil is the same as every other car, just remove the filter and sump plug, let it drain out, put new filter on and plug back in, then fill up with about 4.5 litres of your chosen oil.
I personally change the oil every 5000km instead of every 10000, burnt oil deposits are the main cause of turbo bearing failure so you want it as clean as possible all the time.
jim x thanx.
now with regards to the sump plug-is it located underneath the car??? my magna's one was about drivers side underneath the car.
where is the sump plug for the skyline and more importantly how do i take off the oil filter off. It looks like in a tight position. can i buy a normal oil filter for my skyline. sorry about these qns.
cheers
The plug is towards the back of the sump, I *think* on the passenger side but I really can't remember. I always have to look for it again whenever I change the oil (3 times now) and never take a mental note.
The oil filter can be removed by hand if the previous owner has done it up properly (ie, by hand). Try using a rag to get a better grip. Failing that, try using a filter spanner, but I don't know which type will fit because I've (luckily) always been able to remove it by hand.
Normal oil filters are fine, just make sure you get the right type. I don't know what that is, I just ask my spare parts shop for an oil filter to fit a '95 turbo Skyline and he gets me the right one.
Just to stir the pot,below is a quote from another forum by a guy that says he works in the industry.If you want to read the whole thread here is the address:
http://board.performanceforums.com/forums/...&highlight=agip
"This whole comparison thing is killing me, so i will state what we found is best OVERALL for a turbo charged vehicle after several months of testing in the lab and on the dyno. But, i also must say that it is no reflection of how much better or worse and what is best for eveyones cars out there. Some might be better for performance, some for anti wear and some for length of life.
When i get the chance i will post the full mcdaddy on a new thread that will have an explanation on the outcomes along with graphs on several of the factors listed. So here is what we found to be the best products for a turbo:
1. Elf Excellium 0w40
2. Mobil 1 0w40
3. Agip sint 2000
4. Castrol formula r 0w40
5. Motul 'somthingorather'
6. Mobil 1 5w50
7. Shell Helix (xWx)
so on and so forth...i cant remember the type of motul or type type of shell off the top of my head and there were a couple of more we tested."
    • It was a great, but typical track day, and some VB was ingested at the night time debrief 🤪
    • And so, to round this out, I couldn't be happier to confirm @MBS206 has decided to buy the car. He drove down from sunny QLD with a trailer last week and it is off to its new home today. I'll let Matt confirm on next steps but I understand broadly that the plan is to leave it pretty much as is, and just get some quality wheel time with a nicely balanced car that is pretty much track ready. There are a few a jobs still to be done first but nothing too major and I think its a very smart buy Dinner last night at the Paragon with a round of VBs (mostly) for Neil
    • Well, 50 pages and the end of a chapter for this car. We took it out for a shakedown at Wakie yesterday, and everything went well. There were a couple of niggles: - Oil cooler fitting leak - tightened, cleaned, stopped leaking - Radiator cap overflow fitting was leaking....Mark called it, the overflow fitting was threaded in and not tight....tightened, tested and held pressure - Small oil leak at the rear of the block, probably the turbo oil feed - too hot to get at it comfortably but probably just needs to be nipped up - leak at the driver's side rear brake line where it meets the hardline. Fitting wasn't loose, so Matt backed it off and back on, no further leaks - there's also a leak somewhere on the top of the fuel tank, maybe that cross over fuel line - that was has been left to fix when its on a hoist Otherwise than those niggles the car went great, turned great and stopped great so it was a very successful day out. I'm always really nervous when a car first hits the track after a long break, especially with a brand new engine as well but it was great. VID-20251011-WA0007.mp4  Big thanks to @The Bogan who dropped by and helped out, @MBS206 and my nephew Lachlan the apprentice.  Neil's wife Mel also surprised the hell out of all of us by dropping by; she's up in Tamworth these days but was travelling to Melbourne so had plausible deniability for turning up at the garage, it was great to see her but also obviously a bit sad all round.
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
    • Unsolicited advice? Keep the engine as close to stock as you can. Nothing wrong with adding some boost and making a little more power, but given where you are, you really don't want to try to make it into a monster. I can't imagine the roads are up to it, and the lack of locla support when it grenades will be a ball ache. FWIW, If there is a dyno around that you can access, then brand new injectors are a good idea, which will lead you to (at least) putting a Nistune in it, which will allow you to put an R35 AFM on it, all of which will make it possible to make it much much nicer to drive and live with.
