  • Replies 92
check all your connectors from the coilpack out.
one could be dirty or corroded.
Maybe the CAS... but unlikely with your symptom... best case is to try someone elses CAS if you can...
erm... what else. Usual other stuff, clean AFM, new fuel filter
anything that might upset the fuel or spark is what you wanna chase
Plugs you say.
BCPR6E
They are a NGK V-groove 0.8mm gapped plug.
Thats the exact part number, don't go adding bits to it or changing it. They can be had from Motor traders/Coventrys for as little as $2.80 per plug. Buy else where and they might not have them and if they do you will be looking at $4.80 or something per plug.
Under full load/WOT... Have you checked your voltages? Maybe your Alt is on her merry way?
Has the motor been out of the car? Check all earths. Battery to chassis, battery to chassis to motor, all the little earth straps from the chassis to exhaust manifold, inlet manifold and head. Lots of little buggers around. Well there is on mine. ;)
OK So first thing
I read last night teh plug thing, and i was wondering what the differance is betweens i am running and the BCPR6E, i have also heard of BCPR6ES. I know NGK use to have a plug referance that told you what all the letter stood for, anyone have one? According to the NGK website the BKR6EYA are a direct replacemtn for iridiums that the car is suppose to have.???????
So i will try some of these plugs and see how it goes?
Injectors and clean, as best as i can tell, i checked all of trhem, flow almost all thesame, but i might try some good injector clener, what do you recomend?
I will do a log of the Voltages on teh way home, but as far as i know the alternator is ok, it never runs flat, voltage is 14.2 running, new battery, all seams ok, but will check it, Thanks.
The motor has not been out of the car, but i am not sure if all the earth are connected, as i don't know wher they all should be, will do some research.
In regards to R&R, no issues there, i can pull 13 psi before anythign flattens out, it's like a revlimmiter, not a cut out as such.
Going to do some more researching today.
Was told that a faulty CAS will do this aswell, can somone confirm and tell me what to look out for?
Do the R33 need a different spark plug????
DAM IT???
Funny thing is the problme was not there when car was STOCk it gradualy got worse the more mods i put onto the car. HUMMM...
May sound silly but are you sure you dont have a washer or something in the coilpack bay? I only ask coz thats what happened to me. After months of gapping and silicon, all it was, was a 2mm washer hiding in the well of cylinder 3
Will check it out, but i don't think there is anythign in there to ark out agains. What can i do to see if it is not an injector fault as per this post
http://www.skylinesaustralia.com/forums/in...=129897&hl=
Also is there anyway i can tell if it is just an individual coil doing it.
The thing is if it is an injector or something, would gapping the plugs down fix this?
OK So first thing
The BK plugs are essentially the same as the BC plugs just a touch shorter.
so what are all the EYA things for, i know 6 is heat range and so forth, but the rest. DO you think it is benificial to get the BCPR6E or stick with mine and go down to 0.7mm gap
How can i gignose a faulty CAS?
How do i dignose if an injector is faulty?
Other then that, the car is sooo much better, pulls nice, smooth idle, me like.
thanks budy, much appriciated.
I have gone through the maintnace manual and am going to perform all the test to see what i come up with, susspition is down to CAS or injector, or bad earth. LOL, there is a lot of OR's
Maybe you have a hairline crack in the ceramic of one of the plugs?
I done this once when I used a swivel to replace the plug under the cross over pipe. I had the plugs in and out 3-4 times and only saw the crack on the last. Drove me insane trying to track down the slight miss around 5500rpm that would then clear up and pull well to 7000rpm.
So check them all very carefully. :)
Gap to 0.8mm and then try to get to the bottom of what the 'real' cause of your misfire is.
The boost levels your running you should be able to run a 0.8 gap.
    • You just need to remove the compressor housing, not the entire turbo. I would not be drilling and tapping anything with the housing still on anyways.
    • So, I put my boat on a boat. First of all, I'm going to come out and say it. Why is Tasmania not considered a holy goal, an apex that all road-legal modified cars go to, to experience? This place is an absolute wonderland of titanic proportions. If people are already getting club runs for once in a lifetime 30 person cruises to Tassy then I've never seemed to see it. It is like someone replaced the entire place with an idyllic wonderland for cars, and all of the people living there with paid actors who are kind, humble, and friendly. Dear god. After doing a lap of almost all of the place I've found that it's a great way to find out all of the little things that the car isn't doing quite right and a great way to figure it all out. All in all, I drove for 4 hours a day for a week and nothing broke. I didn't even need to open the engine bay. This is by all means a great success, but it has left me with a list of things to potentially address. I also now have a 3D printed wheel fitment tool which annoyingly hasn't got any threads in it to actually assemble it. I might be able to tape it together to check the sizing I actually want to use, but it'll likely involving pulling the shocks out to properly measure travel at least at the front, and probably raise the car while I'm at it, at least in the rear. I scraped on quite a few things and I'm not sure how else to go about it. I was taking anything with a bump at what felt like 89 degree angles. And address those 10 other tasks. And wash the car. God damn it is dirty. And somehow, the weather was perfect the entire time - And because I was on the top of Mt Wellington it turns out it was very much about to freeze up there. I did something I typically never do and took some photos up there in what must have been -10 and the foggy felt like suspended ice, rather than mere fog. If you own a car in Australia, you owe it to yourself to do it.
    • Damn that was hilarious, and a bit embarrassing for skylines in general 😂 vintage car life ey. That R33 really stomped. Pretty entertaining stuff
    • Hi, I have a r32 gtr transmission. Does any of you guys have an idea how much power it will hold with the billet center plate and stock gearset? At what power level and use did yours brake with or without billet plate? Thanks, Oystein Lovik
    • Saw this replica police car based on a Mitsubishi Starion XX parked next to a 'police box' (it's literally a box) in Hirohata, Himeji City in Hyogo prefecture the other day. It's owned by Morii-san who is a local Mitsubishi Starion enthusiast. According to a local radio station blog post, he always wanted to make a police car himself based on ones he saw in his favourite Manga comics.  As it's illegal to modify a car to look like a police car and drive on the road, Morii-san tried many times to get permission from Aboshi police station headquarters nearby. They refused initially by after they got tired of that they granted him permission. However, the car can only be displayed on private property and obviously can't be registered as long as the police livery is present. The car was completed at a cost of 1.5 million yen (US$ 10,000) in addition to the car cost. A location was chosen outside Hirohata Police box where the car can easily been seen from the street. Morii-san has two other Starion road cars, both widebody GSR-VRs.
