hey again...
Ok i've been doin some research and i've learnt that the r33 gtst's
came out with a medium sized t25/t3 turbo? i assume thats correct?
Also i've read that the t28 turbo which i pressume is a larger more powerful turbo
came out on the silvias from s14 up???
From the info i've read, i gather that the t28 has the same 5 bolt exhaust housing as that
on the rb25 turbo. Aswell as a t3 flange??? Can someone confirm?
Therefore, if i was to get a high flow turbo for my r33 gtst, would i be better off using the
t28 over the standard r33 turbo? has anyone done this etc?
does it just bolt straight in?
Im well aware that theres probably heaps of threads on this already, but when i run searches
the results dont show much in the way of posts that answer this questions.
If someone could confirm that would be fantastic.
Thanks
Guesty.
https://www.sau.com.au/forums/topic/151272-t28-turbo/
Do you know whats involved in hi-flowing a turbo?
The housings are machined out... and quite a bit.
So the actual "size" is changed quite substancially.
Use the R33 GTS-t turbo for hi-flowing
only ask cause i was offered a high flowed t28
wanted 2 know whether 2 get it cheaper
or just high flow mine
https://www.sau.com.au/forums/topic/151272-t28-turbo/#findComment-2814974
SR20's manifold flange run a different flange to the RB25s.
So... you would need to change rear housing, and then have your rear housing (if it was actually bolt on, and im unsure of this) machined to suit
or have an adaptor flange plate laser cut so it would bolt to the R33 manifold.
Lot of rooting around for a second hand turbo
https://www.sau.com.au/forums/topic/151272-t28-turbo/#findComment-2814989
I can't remember the actual compressor housing size of a t28 as compared to a rb20 turbo housing but one thing is for sure...it can handle more boost than the shitty ceramic dinosaur rb20 turbos and will make more power too...
Edited by limpus
https://www.sau.com.au/forums/topic/151272-t28-turbo/#findComment-2816577
if your gonna go a t28 get one off an s15, they r newer and they r ball bearing s14 ones are not ball bearing it only a small thing but very noticeable
On the contrary...only jap spec s14 and s15 t28s are bb...the aussie delivered s15s and s14 t28s are bush bearing...
https://www.sau.com.au/forums/topic/151272-t28-turbo/#findComment-2817687
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
    • You haven't driven many modern cars then have you? Most of them have sfa steering feel with their stupid electric bullshit steering systems.
