Does anyone know what the exact the laws on front mount intercoolers upgrades on cars where stock item was side mounted?
Like to know what it basicaly says, It seems that every one who has a skyline / silvia has put one on so must be ok.
Just like to know, Especialy QLD Law?
Thanx.
https://www.sau.com.au/forums/topic/151314-fmic-laws/
Anyone been booked for having after market inter cooler in the front mount variety?
I have heard a story that your car can be pulled off the road for beeing structurely modified.
I have never had an issue, I gues the good be fussy and get ur for chopping holes in ur car, thats why its best to clean up and holes u have made for piping.
Ive never had an issue with fmic on cars ive had. Dont know the official law tho sorry.
https://www.sau.com.au/forums/topic/151314-fmic-laws/#findComment-2816637
If you are worried i think Trust & HKS make cooler kits where the piping reverts back to the stock location - meaning no holes need to be cut
Im looking into this myself for my r33
Yes, don't go cutting holes in your sheet metal, I got defected for this - apparently effects crumple zones and is illegal. Cop who did me said they pull over everything with a shiney front mounted intercooler - maybe best to paint it matt black.
https://www.sau.com.au/forums/topic/151314-fmic-laws/#findComment-2816665
i got pulled over the other day by cops for speeding and they check my car out and didnt say anything about the FMIC, but a mate of mine got done because his was too shiny! defected for being a distraction to other motorists, so he took it back when the core had oxidised and it was okay'd? (twats)
https://www.sau.com.au/forums/topic/151314-fmic-laws/#findComment-2823542
Guest 40th-edition
Even though i live in NSW im not sure of QLD laws i get done under the emissions act to do with the EPA and defected off the road for having an FMIC, so stuffed around for ages and went to get it engineered and then found out about the front impact bar being modified and have not found a solution other than changing the hole front end with a gtr bar and guards and bonnet and impact to get it oked by my engineer!!
https://www.sau.com.au/forums/topic/151314-fmic-laws/#findComment-2824711
Too shiny , what about the old cars with chrome bumper Bars and Chrome grills ?,
intercoolers cant be much brighter than chrome . >_<
https://www.sau.com.au/forums/topic/151314-fmic-laws/#findComment-2825248
    • -10 is plenty for running to an oil cooler. When you look at oil feeds, like power steering feeds, they're much smaller, and then just a larger hose size to move volume in less pressure. No need for -12. Even on the race cars, like Duncans, and endurance cars, most of them are all running -10 and everything works perfectly fine, temps are under control, and there's no restrictions.
    • Update: O2 sensor in my downpipe turned out to be faulty when I plugged in to the Haltech software. Was getting a "open circuit" warning. Tons of carbon buildup on it, probably from when I was running rich for a while before getting it corrected. Replaced with new unit and test drove again. The shuffle still happens, albeit far less now. I am not able to replicate it as reliably and it no longer happens at the same RPM levels as before. The only time I was able to hear it was in 5th going uphill and another time in 5th where there was no noticeable incline but applying more throttle first sped it up and then cleared it. Then once in 4th when I slightly lifted the throttle going over a bump but cleared right after. My understanding is that with the O2 sensor out, the ECU relies entirely on the MAP tune and isn't able to make its small adjustments based on the sensors reading. All in all, a big improvement, though not the silver bullet. Will try validating the actuators are set up correctly, and potentially setting up shop time to tune the boost controller on closed loop rather than the open loop it is set to now. Think if it's set up on closed loop to take the O2 reading, that should deal with these last bits. Will try to update again as I go.
    • More so GReddy oil relocation kits, sandwich plates, etc. all use 10AN fittings. And same, I've only used 10AN and my car sees track work (circuit, doing laps, not 10 sec squirt business).
    • street use or race track, what hose size and why? what factors change with the hose size options ?   see most comon is an10. when you see most oem external coolers are closer to an12? does high volume oil pump like nitto need an12 or 10 be just fine
