hey mate, i recently got a z tune vent moulded into my 32gtr bonnet i noticed around 15+ degree drop in engine temp.
and rain gets in. but i dont really notice it bieng dirty or anything. just made sure the seal around my cam covers and coils is in good form!
just adding to the thread after reading the rest of it.. i have been pulled over by police on a number of occasions and nothing ever mentioned about the bonnet, or headlight.. or anything for that matter.
oh and id like to say that is the best cai i have ever seen. love it.
  • Replies 68
It's to allow hot air out, that's why it is positioned above the turbos; that's also why i like the bonnet i posted.
Hot air rises :)
Ahhh, makes sense :laugh: How much of an effect on cooling would u think it has tho, i mean that vent is pretty small probably not even palm size. I have to admit it looks pretty nice tho, clean and subtle. Cops wont even give it a 2nd glance.
Has someone got some pics of a raised bonnet?
It doesnt look that bad, but its still noticeable. Just imagine ur normal bonnet raised maybe an inch at the part nearer to the windscreen. It sorta looks like some dodgy panel work has been done. Haha their everywhere around here in Malaysia, seems to be pretty common unlike in melb.
Something like this would be good I reckon.
http://www.j-spec.com.au/list/index.php?ID=9223
The one vented bonnet I do like is the do-luck one. It has those fins that arent too large and over the top but still looks like it would do a proper job cooling. Ive never actually seen one of those do-luck bonnets on a real car before tho :P
edit: actually I don't think they're naca ducts now I look at it, looks more like their designed to use the flow of air above the bonnet to pull hot air through it.
the vspec r34 bonnet duct is a NACA duct.
http://en.wikipedia.org/wiki/NACA_duct
  • 3 months later...
I'm looking at a naca duct.
I have not been able to find a good one yet..
The R34 GTR V-Spec 11 and Nur edition have one in the bonnet..
That is what I'm after.
No bling.. just function.
Porsche 924 have them, lotus, some farrari's.. gt40 even the old forb XA GT had them..
but I still have not found a good one!
Anybody got one?
Please PM me!
Cheers.
Aaron
You can buy a bonnet with a naca duct already installed in it from japan, like a one piece thing. I almost purchased one but then i figured its too much to pay for such a small vent? Im not even sure if it'll work well at reducing underbonnet temps. So in the end i got a shift sports bonnet, with the large centre drop vent behind the radiator which will most probably do its job at cooling. I also got a matching vent cover in case it rains/hails whatever heh :sorcerer:
Edited by Yawn
anyone know how rain would affect ur engine...ie rust easier/quicker?.....water falls into ur engine and blows ur cylinders?
say u get a z tune bonnet for u car and u park it outside everyday and it pours wat r u gonna do?
or say u goto work and u have to park outside for 8 hours and it rains for those whole 8 hours?
how will this affect ur car?
ON A TT SUPRA we did some testing at wakefield with streemers on the front bar and on the tip of the bonnet. and on the straight the ones on the grill and upper of the intercooler they were pointing forwards lol. the only thing pulling the air thru the radiator was the engine fan.
thisa was with a louverd bonnet. and a standard bonnet. and no bonnet. all made no differance to watertemp. the only thing that worked was having the intercooler cut in half so the radiatio gets its own air. and a curver partition seperating the rear of the cooler fronm the radiator area. with the cooler venting thru naca ducts on the bar.
also lifting the bonnet is a good trick. but the air doesnt go out of it. but back into the bay and pulls the air under the car.
im gonna try the same idea on my car at our next test day. cos ive got the same issue. at high speed it just gets hot. im no aero dynamacist but im learning
    • I'm looking for some real world experiences/feed back from anyone who has personally ran a EFR7670 with a 1.05 exhaust housing or a .83 I'm leaning towards the .83 because its a street car used mostly for spirited driving in the canyons roads. I"m not looking for big numbers on paper. I want a responsive powerband that will be very linear to 8000 rpm. I dont mind if power remains somewhat flat but dont want power to drop off on top. The turbo I've purchased is a 1.05, although the mounting flange T3 vs T4 and internal vs external waste gates are different on both housings, I not concern about swapping parts or making fabrication mods to get what I want. Based on some of the research I've done with chat gpt, the 1.05 housing seems to be the way to go with slightly more lag and future proofing for more mods but recommends .83 for best response/street car setup. AI doesn't have the same emotions as real people driving a GTR so I think you guys will be able to give me better feed back 😀
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
