Guest Boxhead
yeah i understand your pain mate, i have that maguairs window cleaning stuff, it doesnt work that good.. seriously i have used it once, now everytime i just use windex from under the sink hahaha....
um i was on a toyota soarer page, and they had this stuff advertised that was meant to do the trick... just go in and ask them, and show themn yoru headlights..
the mob at my autobarn are evry helpful, most of em are young and interested in cars like me... so they want to help on a mate basis aswell.. but i dunno :S
https://www.sau.com.au/forums/topic/1516-plastic-headlights/#findComment-29739
Try giving it a polish first....
I thought it was in the inside, and i had a look and it was too much trouble to take it off. Anyhow, I read another thread a while ago on this, so i decided to polish mine... Came up looking much better. If that doesnt work, then i guess it is on the inside (highly unlikely unless it is not sealed and is leaking somewhere).
https://www.sau.com.au/forums/topic/1516-plastic-headlights/#findComment-30410
Plexus works realy realy good, its avaliable at most autobarn stores, its a spray kinda polish that will bing it up like brand new, it cuts and polishes clear plastic, thats whats its designed for, it also does alot of other surfaces ...
https://www.sau.com.au/forums/topic/1516-plastic-headlights/#findComment-31479
Yep its called PLEXUS, trust me when i say its the best stuff ive tried ..... I carnt beleive how new my lenses looked ...
It was designed for aviation for cleaning there gauges and stuff..
There is an actual site for it ...
http://www.plexusplasticcleaner.com
https://www.sau.com.au/forums/topic/1516-plastic-headlights/#findComment-32519
Its a bit scary but acetone works well as long as you are quick and only go in one direction it simply eats the dead surface away I used it on my old TR Magna indicators which were a bit yellow and they came up like new but I would suggest a bit of practice somewhere inconspicuous first!!
https://www.sau.com.au/forums/topic/1516-plastic-headlights/#findComment-43511
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
