Hi
I bought my stagea a couple of months ago - i bought it with a dual sunroof assembly, all that was needed is the sunroof buttons/control panel.
These buttons have been paid for, but now i cannot get in contact with the person who is meant to be getting them. Supposedly he does (or used to) business on here for stagea people.
I did get in contact with him last year, but he has been in japan and his wife (i think) had been answering the phone. I was told to try in the beginning of january as he will be back from japan then.
All i know is a name and number
Trevor
0422010562
Does anyone know his user name? As i would really like to get these buttons/control panel especially since they're paid for already.
BTW - the previous owner of the car is helping me as much as possible also.
thanks
-Matt
https://www.sau.com.au/forums/topic/151940-sunroof-buttons-help/
well supposedly he is a forum trader, or deals through here and its the only way of linking him to a user name - the number isnt taking calls at the moment either , and this is the number he uses for business purposes. >_<
if goods are paid for and a person isnt contactable - what else can i do?
-Matt
Edited by huddy
Do you think it is very nice to post someones mobile number on a public forum?
His details are already on the parts forum Ska.
QUOTE(darrinspencer @ 20 Sep 2006, 09:37 AM) *
Just found another parts dealer
Trevor
Melbourne
0422010562
Has to 2 complete series 1's, one has leather and twin sunroof's
Has 2 more complete cars coming for wrecking
  • 1 month later...
    • The oil pressure sensor for logging, does it happen to be the one that was slowly breaking out of the oil block? If it is,I would be ignoring your logs. You had a leak at the sensor which would mean it can't read accurately. It's a small hole at the sensor, and you had a small hole just before it, meaning you could have lost significant pressure reading.   As for brakes, if it's just fluid getting old, you won't necessarily end up with air sitting in the line. Bleed a shit tonne of fluid through so you effectively replace it and go again. Oh and, pay close attention to the pressure gauge while on track!
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
