I have a stock car and as you may or may not know the turbo went bye bye recently due to or not due to a dump pipe installation that may have or may have not gone pear shaped when they were fiddling around my turbos holes... lol...
Anyway I was going to order a GT3040 the other day when I realised I dont want a lag monster of a car. So my descision is now a GT30R.
I was going to order the GT30R yesterday when I realised it just wasnt that simple. Garrett have a few flavours of the GT30 series...
GT30
GT3071R - 700382-3
GT3071R - 700382-20
GT3076R - 700382-12
I have no idea which one to order, is anyone able to tell me from the spec sheets located:
Turbo by Garrett
Under Medium section, GT30 series.
Any help is appreciated, would like to order one today.
Paul.
https://www.sau.com.au/forums/topic/152068-garrett-gt30r-flavours/
  • Replies 131
You dont want either of those 3071's. You want this one;
http://www.atpturbo.com/Merchant2/merchant...tegory_Code=GRT
What sort of power do you want? What sort of response/boost threshold? Answer these 2 questions and it will make it easier to pick a turbo.
Well my aim was 300kw at the end of this year, I want a turbo that can get the power at ~3000-3200 rpm. I was going to do a turbo upgrade 4 months from now after I had bigger injectors FMIC, management and all that jazz. But now I am forced to do it now, I got no time or money to play around with another second hand turbo or new stock one from nissan.
If you were staying bog stock then the 3071 BHDave suggested would be slightly more responsive for 300 rwkw I would be going GT3076R - 700382-12 with the .63 AR turbine housing.
On a SR the power comes on about 3500 rpm the RB25/26 should come on around the 3000-3200 your looking for. I have spoken to a few people running them and they are a very streetable turbo for the larger RB engines.
Who are you planning to buy from? Morrie from HPinaBox generally has very prompt delivery and knows his stuff if you don't have someone already lined up.
I run a gt3076r with 0.82ar and its awesome response and power. I am only running 16psi and make 260rwkw (heaps more in it) on a really safe tune and with supporting mods. So I would recommend them on a rb25 and with the smaller 0.62 or 0.63 it would be even more responsive.
Paul,
3200rpm and 300rwkw. It won't be happeneing on an RB25. >_<
RB30 yes, but RB25 no. :happy:
You will be looking at ~4000rpm until your pinned in the seat.
Well on Shauns dyno anyway.
I was under the impression that he was looking for boost to start comming on around 3000-3200 not actually have the 300kw. It will be up towards red line before he get 300kw but boost should start to come on around 3000-3200.
Paul,
It'll go close. Probably boost all in by 3400 and 280odd rwkw with the 3071 in .63 on the dyno.
Probably a touch sooner on the street in 4th.
Shit, if my old T300s lump can make 1.4 bar by 3200 in 4th on the street and go on to make 288rwkw, then a new generation 3071 in a .63 should decimate it response wise and have similar top end with better transient response.
I have a stock car
I was going to do a turbo upgrade 4 months from now after I had bigger injectors FMIC, management and all that jazz. But now I am forced to do it now, I got no time or money<snip>
U wont be wanting to stick a gt30 on by itself then. Unless u want another dead turbo soon, or can resist the right foot...
Yes thats fine.. :happy: I was talking about whats considered to be the real GT30r (6blade etc) .82 that will crack the 300rwkw mark.
That old T300s looked like quite a good thing by its dyno sheets. >_<
The GT3071r .63 I think will struggle past 260rwkw. They are responsive but..... well I really think GT3076r 6blade .82 is for 300rwkw, even then it is on its 'limit' and won't be done unless you run some good boost 20 odd psi, cams might possibly be needed. If you want to step down slightly and pick up a little more response grab the 52t GT37 comp wheel.
Discopotato03 is the man to speak to he knows all the ins and outs of the GT30 and its compressor wheels. He has a thread laying around in here some where.
    • Nice, thanks for sharing your progress....that's a pretty long list you are putting into it!
    • Decided to upgrade my pressurised plastic coolant expansion tank for a fancy pants alloy version The OEM versions can get brittle, even the new plastic one I got when I first got the car is a starting to show signs of "stress" I wasn't cheap, but it is basically unbreakable
    • Morning all, I have an RB25DET Neo that's in need of a rebuild. Will need new pistons etc due to detonation damage. Would anyone be able to recommend a shop in Southeast Queensland who I could bring my long motor to for a rebuild? Just want someone who knows RBs and whos built a bunch of them before. TLDR - recommended engine shops for RB rebuild.
    • Gday Thought it was about time I started a build thread! As expected this project has snowballed into a huge financial liability, but unless you’re strong willed and responsible, it’s not a surprise. Background -  My first turbo car was an R32 GTS-4, got my full license and then totalled my Au Falcon a week later, so while trying to sell my RMZ450 dirtbike to buy another car a bloke offered to swap the R32 which at the time I felt like I was ripped off but looking back and seeing prices of those now ($40kish) it was a good deal, I didn’t know enough about these cars to appreciate what I had so sold it before the RB20 blew up. Between here and there, out of 12 cars I’ve owned the note worthy ones are a V8 Lexus SC400 (soarer), a couple of XR6 Turbos and my beloved S15 which I had for about 3 years, picked it up for $12500, repairable write off but she was fine, gun metal grey/pewter and bone stock/unmolested until I got my hands on it. Ended up spending about the value of the car and 280kw, 2 demerit points by the time I got defected and sold it for $14500 (also $40kish in today’s market, rip) Fast forward to the present day, I’m in a much better position financially and daily an MQ Triton (great cars, pipe down Ranger Bois), I cruised marketplace and car sales for a few months looking for another R32, the best deal I could find was an absolute rust bucket half finished project for $12000, until this R33 popped up in Port Macquarie for $18k - unregistered and barely running but decent shape, kept an eye on it for a few weeks and the price steadily dropped, $16k then $15k then $14k, that was the point where I was like shit someone’s gonna snatch this up! It was owned by a young bloke who had big plans but him and his missus just had a baby so smartest move financially for them but big gain for me. So 2 days later I’m towing a car trailer to pick this thing up. Roughly 2 weeks and $3500 later I’m cruising around Newcastle in my beat up R33 all smiles and dose noises! It only needed some basic shit to get it going, coil packs and air flow meter, electrical stuff and all fluids changed, 158k kms and running pretty good, nice smooth engine after oil and coolant flush - when I say coolant I mean it had been filled up with tap water, every gallery and heater element was filled with rust, 8-9 flushes later and still had brown liquid coming out but she’ll be right. The car was painted R34 Bayside Blue at some point but whether it was a cheap job or just not looked after is anyone’s guess, clear coat flaking like sausage roll.  Was rethinking my choices and contemplating life, had it up for sale for $22k - still cheaper than any registered R33 but got little interest, next minute I had an opportunity at work - 6 months overseas for good money, so that was a no brainer, fast forward again and here we are with a 50% finished project. Current Mods - 200ish KW according to butt dyno Was tuned with Apexi PowerFC EBC (old school Greddy Profec)  Stock turbo (more shaft play than a Tinder date gone right) 3inch turbo back Varex muffler  Aftermarket injectors of mystery size, Power FC showed 36% duty cycle at full boost so not behd good size Someone had good intentions but stuck with the stock R33 MAF so we had misfires at 6000rpm due to the MAF hitting 5.2V So far I’ve redone the entire interior with carpet form Car Mats Direct, new Seats and steering wheel from Autotechnica, also sound system by Autobarn (mainly Kicker) Also MCA pro comfort coil overs - Hands down best purchase yet, worlds of improvement over the tired 30yrold shocks Goals - 450kw/600hp on flex tune New paint job - Midnight Purple 2 Engine is at the shop getting rebuilt with forged rods a pistons, new valves and springs, ATI Harmonic balancer, Aeroflow 7.5L sump, rear head drain and oil restrictors as per oil control thread* and cam covers modded for larger breathers, other stuff I can’t recall of the top of my head Parts purchased and to be installed once the engine is done -  Engine loom from Wiring Specialties including these options: Haltech Nexus S3 R35 Coil pack conversion  PRP Dual Trigger kit Fan controller  Other Parts -  262 Kelford Cams Turbo - Hypergear ATR43SS3-ProS with T51R mod (whistly boi) 6 boost manifold (high mount) 50mm Turbosmart Pro gate (plumbed back for legal reasons) HKS Super Turbo Exhaust with High Flow Cat Custom 3.5inch dump and front pipe 1500cc Bosch injectors  Fuel Pump walbro 525 Haltech MAP and IAT sensors Haltech Flex Sensor Fenix Radiator with dual thermo fans LS1 Alternator Kit Oil Filter Relocation from EFI solutions and Cooling pro oil cooler Many other things sitting in my garage waiting for that engine to come back. Progress pics to follow -
    • Losses have to be less with DC coupling. Provided the battery inverter has decent MPP tracking ability - which really shouldn't be a problem. It's not 2005 any more.
