smashed in the front but by a wank in a porsche. Insurance says no fix - repairable write off
Passenger side rail bent and wheel moved back slightly.
Looking for people who would be insterested in buying the car deregistered for repair or taking offers to part the car out.
Details:
1989 factory GTST 4 door
Converted from auto to manual
standard wheels
gtr sideskirts and rear pods
RB20DET with hardcore heavy clutch, twin or single tight as.
Short shifter on rb20 gearbox good condition
Blitz BOV
All Interior and exterior bits (no aircon vents)
3" jap exhaust of some kind nice and quiet
JIC coilovers dampener adjustable $600
4pot brakes and rotors up for grabs
rear irs cradle and diff (hubs) suit s13,a31 5 stud conversion
4 door taillights
seats
Basically it was a complete mint 4 door. :D
If u are interested PM or call me on 0408 989 486
:) Ray
https://www.sau.com.au/forums/topic/152299-eoi-wrecking-r32-gts-t-4door-manual/
I don't think this guy is replying...
Anyway, if you do reply mate post a pic of the exhaust. You say some "jap" exhaust, is that because of a symbol on it? It might be Kakimoto. Do you have the spare space saver wheel also? Thanks.
-Jimmy.
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
