I received my strut brace and brake lines today. Thought they were pretty.
Not real CF unfortunately :), but it does only weigh 1.2kg
jicstrutbraceqk2.th.jpg jicstrutbracecloseuppw6.th.jpg appbraidedbrakelinesci2.th.jpg
Someone at JIC can't spell, lol
And along with the reset of this crap I should be sit'n pretty.
Going in for the stainless kermit intake piping soon. Hopefully next week if kermit is ready :D
apexireplacementfilterspd1.th.jpg bilsteinshocksag6.th.jpg whitelinespringsum2.th.jpg whitelineswaybarswu8.th.jpg
No sticker HP this time but now the R needs rust repaired on the rear guard, bonnet and bar resprayed.
I've been putting that off for too long :D
Say Hi to your mum for me :D
https://www.sau.com.au/forums/topic/152342-happy-snaps/
brace was from Perfect Run. DCS carbon fibre model.
http://www.perfectrun.com.au/performance%2...rutbracebar.htm
Cost was $201, although my conversion of Y18500 using www.xe.com came to $195 but oh well. Shipping was for 2.7kg which included the brake lines and it came to $59.
https://www.sau.com.au/forums/topic/152342-happy-snaps/#findComment-2834215
  • 3 months later...
aha! So me and Scott convinced you over to the bright side :(
Brad, was it that sqirmish take off against Paul that convinced you?
Sorry bout the thread jack Tom.... i'll save it buy saying "nice pictures, and where did you get the break lines? PM pls"
https://www.sau.com.au/forums/topic/152342-happy-snaps/#findComment-3102367
I just relised that i hate the look of the rear of a R32 GTR, so as i cant pass them, i may aswell drive one to save me from looking at it!!!
What im looking for is a really really clean and tidy STOCK 32 with low kilometres. If i cant find one, i wont buy one.
As for my take off against Paul, was he trying at all or not really??
Oh, nice floor mats Tom. :P
https://www.sau.com.au/forums/topic/152342-happy-snaps/#findComment-3106536
I though so too, with the Nismo twin it should feel more like stock.
Hate the 32 rear end? Its the nicest of all 4 main Skylines :domokun:
Most of the 32 GTR's coming out of Japan are the 1994 models which are Vspecs with the BBS's and the Brembos. As for low km's and stock these are your best option, obviously, but you can never know if the Japs run the clocks back a few 1000 k's. Just look for a Grade 5 on Prestige or whatever...
Sorry for the hijack...... wait a minit!
https://www.sau.com.au/forums/topic/152342-happy-snaps/#findComment-3109458
Tom do you mind stop hi jacking your own thread!
thank you!
Interested to see how your clutch goes though. Bringing her out to next wanneroo night?
p.s. Have to have a look at fair pricing on GTR's to. May just be a bit more than i want to pay.
https://www.sau.com.au/forums/topic/152342-happy-snaps/#findComment-3109723
Probably not too soon, I have insurance for both my cars (I bought a MKII Escort last week) and credit card debt (the clutch money) and owe my parents like $700 still so maybe later in the year. Should have the high power floor mats in by then too :( (she needs a vacuum)
https://www.sau.com.au/forums/topic/152342-happy-snaps/#findComment-3110610
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
