For sale: 2001 Nissan Silvia S15
Asking Price: $70,000 ( have receipts for roughly $115,000)
Killometer's: 53,000 kms
Manual or Automatic transmission: Manual ( strengthened 6 speed)
Engine Type: SR20DET 2.0
Modifications: (see below)
Complianced: Aus model
Road Worth Certificate: Can be supplied for vic
Registration: Yes 12 months (vic only)
Crash History: No Accident History - Inspection Welcome
Location: Victoria Shepparton - hour and a half from melbourne for those who dont know
Contact detail's - Steven Martin 0418374944
Car is currently the cover car for Fast Fours Magazine (feb 07) also coming up on ignition DVD in coming months.
Appeared at one show since complete (autoson final battle 06) where it won 4 pro class trophies
Full feature with most specs in current fast fours any questions feel free to call,
email or add me to msn [email protected]
UNDER THE HOOD
- SR20DET DOHC 16V turbocharged and intercooled 4-cylinder with detailed engine bay, braided lines. annodised fittings, custom aluminium radiator, overflow tank and oil/air separater
- Arias forged pistons with chrome moly rings, shotpeeded conrods, GREX head gasket, ported and polished cylinder head
- Polished bell mouth intake, GCG T66 turbo, custom front mounted intercooler and piping, GReddy inlet plenum, Blitz 850cc injectors, SARD fuel pressure regulator, Blitz I-color electronic boost controller
- Custom tuned-lenght exhaust manifold, Tial external wastegate, custom 3" dump pipe, custom mirror polished 3" exhaust system, x-force muffler with 4" tip
(car made 283kw at the wheels with alot more to go - tuned very safe, car is capable of an estimate figure of around 320kw)
DRIVELINE
- Strengthened 6 speed gear box
- Blitz twin plate clutch
- Standard LSD differential
- 365mm slotted rotors and G4 8 piston callipers (f) slotted rotors and mu's secret pads ®
SUSPENSION
- Buddyclub coilovers
- Every single suspension component is either chrome or painted in 2k
WHEELS
20x8 Gestalt 3 Diamond Series wrapped in 20" pirelli tyres (f)
22x9 Gestalt 3 Diamond Series wrapped in 22" pirelli tyres ®
INTERIOR
- 2005 STI front bucket seats , full tan leather re-trim covering seats, door trims, shift boot, dash etc. with suede head lining
- Autometer gauges (Boost, oil pressure and fuel pressure)
STEREO
- Kenwood 7" DVD Source unit
- Rockford Competition splits in front
- Rockford Competition splits in rear
- Rockford mirrror polished 2 channel amplifiers x 3
- Rockford Pro series Mono Amp 3000 watts RMS
- Rockford Pro (T2) 12 Subwoofers x2
- Custom Boot install inc fibreglass 2 pac painted sub box
(roughly $20,000 just in audio gear there)
EXTERIOR
- Full Vertex Body kit
- Scissor door conversion ( not a cheap one) high quality kit
- Custom candy Pink to Purple blend in house of kolor by queen st smash
Edited by STEVEM
https://www.sau.com.au/forums/topic/152399-fast-fours-07-cover-car-for-sale/
I suggest posting detailed specifications on the car you are selling given the asking price as this will avoid a stampede of people asking you whats been done and why the price tag.
  • 1 month later...
  • 4 weeks later...
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
    • The video for the servicing and fuel filter change can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44 One of the main jobs I wanted to do before the car officially went on the road, was to remove the awful looking blue silicone hoses. There's nothing wrong with having coloured silicone hoses, but I realise as I'm getting older I prefer monotone engine bays with a splash of colour on the engine cover(s). I cover this in a lot more detail in the Youtube video, so unfortunately there's limited photos of the process. The intercooler, upper radiator, boost vacuum and upper breather hoses were all changed to black silicone with mikalor clamps. The only blue left is a blanking cap at the back of the inlet manifold and the GReddy pulleys (which will be replaced for stock when the cambelt gets replaced) While the intercooler pipes were off I gave them a quick clean/polish too A before photo I do have a replacement air filter on its way. Fuse box covers were painted blue, they're now satin black Another job on the list while the bumper was off, is to add some mesh https://live.staticflickr.com/65535/54737966256_99b28bfa30_c.jpg[/img] I was hoping to use some thin wire to secure it, but it seems I've misplaced it and the wire I had was too thick to twist easily. I ended up using cable ties for the time being https://live.staticflickr.com/65535/54737131882_c2b7989dcc_c.jpg[/img] Was pleasant to see this https://live.staticflickr.com/65535/54737131627_8b2aab13b3_c.jpg[/img] The last thing to do was to fix the front grill and re-mesh that to match but I ran out of time The Youtube video can be seen here: https://www.youtube.com/watch?v=R4FsF6tgizE&t=23s
    • Hi all,I already introduced myself in the Victoria section, but only saw this section now lol XD New to forums and new to skylines. Hoping to buy my new skyline within October
