would the n1 headlights for the r32 have the same wiring as the normal r32?
has anyone tried this?
I can't confirm - so a bit useless really, but I would imagine it's exactly the same plug. If it isn't it'd be a relatively easy re-wire. If I had to bet my money would be on the same plug (knowing Nissan of the era).
whats the difference between the n1 headlight and standard gtst headlights?
N1 lights look aggressive as all hell. My dream r32 wouldn't be complete without them, they have a squarer looking section, kind of like the difference between Aus spec r31 lights and JDM r31 projector lights.
https://www.sau.com.au/forums/topic/152402-n1-headlgihts/#findComment-2835732
n1 use h4 as the main headlight...whilst the stock ones use i think h1 or h3 cant rem. As with wiring from memory....might have to change to H4 plug. Can check if your really desparte to know. pm me
when you unplug the H3C light, dont unplug it from the globe. There is another plug that leads to the highbeams so both low and high beams share the same plug leading to the main loom. So unplug it from there...its considerably bigger. You end up using that bigger plug to connect to the hi/low H4 in the N1 headlight. Parkers use the same plug. And then there is that extra plug that will be tucked away (somewhere towards the grill). It wont be plugged into anything, and thats the one you will use for the fog/driving lights
Edited by [WLDCRD]
https://www.sau.com.au/forums/topic/152402-n1-headlgihts/#findComment-2837739
far out, here i was thinking.......the above pic was GTR headlights, and the bottom pic was standard GTST, i had both on my 32, wired exactly the same, i just plugged em in, got some really bright white H4 lamps and bingo, she work and light street
https://www.sau.com.au/forums/topic/152402-n1-headlgihts/#findComment-2838076
    • Yeop... binned it   This will be a summary will not many pics atm and cbf  Fixed the samsonas - it was totally munched Put a new precision 7675 T4 on with proper split pulse mani Got to Sydney to get to car - drove to canberra to get racecar - drive back to sydney that night Next day all day at Plasmaman putting on new clamps cleaning some things up and adding another large engine oil cooler sitting at the rear above diffuser to keep things cooler Next day - Tuesday - on Dyno - killer wikid awesome pumped out really good numbers - more mid range and on lower boost levels Wednesday - first prac - all day again getting the suspension right - had to borrow front suspension again - out do a lap come in - out do a lap - in - what i had just couldnt handle the load at the more consistent higher speeds - got a lap in at the end of the day that was pretty reasonable  Put it this way that lap wouldve had me in 4th in Pro am for the whole event - with only 700 hp and used tyres Thurs first official prac day - lap out warm up - with above setting and 80% effort took corners 1,2,3 and into 4 car felt awesome -  rear came around out of nowhere bang into the wall near front on at whatever 140 kmph Done, over, gone Just one of those how did that happen apparently as all indications show nothing out of the ordinary Got to spend the rest of the time at the event like I hadnt done before - was actually Ok mainly as I had my family and my boy is 9 and got treated like a rockstar Long trip home, lost a trailer wheel in nowhere land, X5 airbag suspension gave up half way across nullabour and rode on bumps stops (its now completely fine) had to do a 19 hr drive day on day 3 as accommodation got screwed up so just had to keep driving till found a town with some Now to reassess - there is no easy fix there is no i'll just order that part and get it sent - we'll have a talk to people see what can happen and what the go is but at minimum its rebuild from scratch struts forward and alot of time effort and $ should and if I return and if but maybe/ when  I have the cage tied into the front strut towers - if I didnt have that things couldnt been worse you can say its just a front end but if you know what goes into these cars... you'll know what that actually means in reality   Car was very fast. Disappointing we just didnt get to show it     Apparently this is motorsport !
    • Thanks, will do that.  Thankfully they still feel great.
    • Yeah man, absolutely. You can try pushing me all the way in swapping the R34 for an E9x M3
    • It's almost certainly going to be some amount of pads compound transfer onto the rotors. It will probably go away after you've run them for a bit. If not, pull it all out, lightly sand the rotors, scuff the pads, and rebed.
    • no one recommending speedtek gearsets?   i'm in the same boat as Cosline but rwd, I am holding boost back in third to 600nm at the hubs to save the gear as i make nearly 750nm at the hubs on a mainline
