Just ran a 12.9 on Sunday at AIR. Pretty average 60 foot of 2.247, was getting mega axle tramp.
:rave:
Car: R33 Gtst
Mods:
HKS exhuast, 3" dump and cat-in pipe
Greddy FMIC (Model- 28c)
Apexi Power FC
Apexi filter which has a cold air feed and partition
Oil/Air seperator ( single inlet )
HKS twin plate solid centre clutch
Heat wrapped Turbo dump to cat, Intercooler outlet to throttle body.
Turbo is totaly stock
Bocsh Motorsport fuel pump
BP ultima 98 with Wynns Octane booster.
Motul 6100 engine oil
Last dynoed 218rwkw
Estimated 220-230rwkw on the day.
Next Mods
HKS adjustable cam gear
high profile rear tyres to get the 60 foot time down
- hoping for 12.6-12.7 :burnout:
https://www.sau.com.au/forums/topic/15265-129-11149-stock-turbo-gtst-33/
  • Replies 77
I removed the exhaust at the Cat and increased my timing by 2 degrees because of the octane booster advantage. Also modified the front bar for better flow through the cooler and heat wrapped the exhaust the day before, which made noticable difference to intake temps.
My best run however was with the exhuast on.
Thats some impressive power your making out of those relatively basic mods. How long ago did you install the PowerFC, early on or later on?
14.7psi is abit high on the stock turbo, I get told that 12-13psi is a risk on warm-ish nights.
I think if you can get your traction problems sorted (thankgod someone else gets axle tramp, was beginning to think i was the only 1) then you should see a 12.7-12.8 easily.
oh i get axle tramp alright.. although i am not quite sure exactly what it feels like so not positive! If its the feeling where you're tyres aren't quite squealing and your ass end feels like its bouncing up and down while the wheels are spinning then i get axle tramp big time?? so you are not alone.
As far as i can tell the best way to fix it would be get rear suspension as hard as rocks or put 100kg in the boot. I have pineapples as well, reduces it a bit but not enough as i would have liked.
Thats it alright. I think my car launches harder with 2 people in the back then what it does with just myself. The extra weight most deffinetly helps. I've got 2mth old Koni Shocks and 4mth old Pineapples, my last bet is new Dunlop FM901's to replace the Falken ZE502's. If they dont fix the problem (or dramatically improve it) im not sure what else can be tried. I just wish somebody could give a reason as to why it happens (too hard, too soft, wrong setup, etc).
What an awesome result - congrats:) Hope you got another turbo waiting nearby :P
Have you thought about going for a solid alloy spacer in place of the front pineapples - I have heard it can work wonders, just locks the whole thing up.
yer..same prob.. I've got the Falken's as well. It's just that the skyline is not too balanced.. weight distribution could be a lot better for dragging if it was more even. A full whiteline kit would do wonders if you want to spend the money.
I can probably do a bit better and get a mid-13 but not much better i don't think with my current setup and a few tweaks.
Hmmm.. I've only got pineapples on the ass end actually as i thought that was mainly where it would be needed in a RWD. Would I get gains from having them on the front as well?
I was running 17" 35 series tyres with 20psi. The track was ultra sticky. First run I tryed with a burnout and ran a 13.6. After that i decided to skip the tyre smoking and drive around the water, ran constant 13.1's and the single 12.9 after that.
benm: I installed the FC over eight months ago.
111mph! what the!
I think I'll get a 12.9 soon but, 111mph is damn fast and indicates alot of horsepower.
Go the whales!
I think that puts the R32 boys in their place, they need hiflows toget those sort of times :P
What was the 60ft? (I'm guessing a 2.1)
Looks like AIR got its shit together this time! The warmer day time track temp' would certainly help. It was faaar from ultra sticky last s/meet :P.
Damn I wished I'd gone now :P Nightcrawler set a PB this meet too.
Originally posted by rev210
111mph! what the!
Dave,
111+mph is more than some people would have you believe the stock turbo & injectors can manage!
That little stock turbo is a freak for sure :P It provides minimal lag, hence the quick 1/4 even with a so-so 60ft, yet has big top end to run 111+.
Matt,
be very careful about what you upgrade your turbo with. You could go backwards!
    • Robertson was a Canadian inventor, and it absolutely reigns supreme here. 95% of our screws are Roberston. It's literally the only option you can buy off store shelves. What would it have lost out too? I believe it's also very popular in the US.  My reference to imperial was pointed to both NPT and BSP.
    • No. BSP lost to the cultural/technical imperialism of living next to Trumpistan. Face it, Robertson screws were better and still pretty much lost out to the yank stuff. The Europeans hate the Brits and they don't use NPT. NPT is just as "imperial" as BSP is, being based on those useless inch thingos. Just done differently.
    • I live in Quebec. Our license plate slogan is "Je me souviens" Translated is "We will remember" as a reminder to when England conquered us and that we must never forget what they did. Long story short, BSP is unheard of here due to being an English design. I'm surprised our nazi anti english government office the OQLF hasn't kicked in my door yet just talking about it, yet alone imperial anything.
    • Thanks for that! I did a quick Google search looked up some of hydaulic stores and didn't see it listed on the website, I'll give them a ring. Also found out later that I can buy 2 oem bleeder bolts for 10 bux and come with the washer which I might do so I don't waste the money it costs in petrol to find 2 washers (already did that lol). The old copper washes look in good nick, I drove it after taking it off and putting it back on and didn't see any  Part number here for reference if anyone needs: 14053-42L0A
