whats a TD06 worth? sounds awsome. I also have heard of a TD05/6, anyone else heard of this? apparently good upgrade for RB25 and has very quick spool up with good top end, although full boost by 3grand from the 06!! damn isnt that as good as standard?
  • Replies 77
Hi JMS is that you car on the Tilbrooks dyno graph on the "Which Trust Setup?" post?
If it is can you please have a look at the following table and let me know if it is close to what you have experienced...
At 7,000 rpm it has 300 rwkw
At 6,000 rpm it has 250 rwkw
At 5,000 rpm it has 195 rwkw
At 4,000 rpm it has 93 rwkw
That's an average of 210 rwkw.
To work this out I assumed on the dyno it was in 4th gear and running 27 kph per 1,000 rpm. I had to do this extrapolation because the graph did not show rpm.
I would appreciate your comments.
Actually got to drive the JMS 302rwkw GTST last night (thankyou Terry). I must say I was quite impressed. That car doesn't have the usual huge jap turbo sledge hammer effect at all ,but, was quite progressive power delivery. Very drivable even through tight cornering- no opps I boosted at the wrong time and did a 360! The turbo lag was noticable and took a slight change in driving style. Instead of just planting your foot for instant boost I had to change down a gear and use the revs. A familiar woooosh comes from anything over 3000rpm and a shove in the seat really takes effect after 3700rpm. The cars redline is set to 8000rpm which still provides ample rev range to play with. Would be lieing if I said I wasn`t grinning from ear to ear inside ( couldn`t let on to much that I`ve never driven a car with that much power b4 and Terry said he is a girl in the passinger seat) when I was frying the tyres all the way through second and third!- not enough road for fourth.
sidewaymambo- definately no instant throttle response if thats what your getting at. Extremely good compared to other cars "I`ve" driven with hiflo and big Jap turbos
Sydneykid- You seem to know better, how about you tell us what its like since you have never even seen the car. ciao
Guest Sir Bean
Originally posted by macka
TT anything that spools under 3K isnt going to produce alot of horsepower mate
This simply isn't ture. New generation turbochargers using variable turbine geometry and variable pitch turbines work to eliminate lag. They are more responsive and create higher boost pressures at lower engine speeds than conventional tubochargers by altering the internal geometry of the turbine housing. The boost pressure is optimized across the engine speed range by adjusting the guide vanes inside the turbine housing. At lower engine speeds, they restrict the flow and thus boost pressure is increased; at high engine speeds they open wide and the exhaust back-pressure falls, restoring top-end power.
These things would be simply awesome on the side of an RB.
I hope that brings people up to speed. No pun intended.
Originally posted by Sydneykid
Hi BOOSTD, did I read this right.....
"I was lookin a getting a trust TD06. Terry from JMS just installed one onto his Rb25 powered 32 and made 308rwkw @1.2bar and full boost a 3000rpm."
had another read, still says full boost at 3000
was replying to the quoted post not the above one, i must have been skipping around the thread a bit.
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
    • Thanks for the replies everyone. Definitely a coolant push. Oil catch can is empty and always has been. As the engine is out now I'll be having a good look over things. I do have some detonation on the piston tops from a trigger issue back about 5 years ago. I felt it and shut off then bought a new ecu and changed the trigger. Never been an issue since. It never hurt the power, its made almost 80hp more since that incident but I will pull the bearing caps to take a look. If the bearings are damaged I will do a bottom end refresh. Head is being re conditioned at the moment and the block will be cleaned and checked to ensure it's flat. I'll go with a kameari gasket and see how it ends up. The other thing I'm not super keen on is the cylinder colours. I suspect this is from the inlet manifold. The plan will be to put it back together, retune and then stick a plazmaman billet inlet on it and retune. I'm happy with the power, if it makes a little more, then great, but I would rather just make everything more efficient at this stage.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
