Hey peeps
Just a few quick questions,
I spoke to my workshop who said it maybe a better idea to get a Walbro pump over a Bosch as they are harder to mount? First up i have no idea where to get a Walbro pump from.
Im looking for about 350rwhp(approx 260rwkw), will a Bosch 040 do the job ok?
Also whats the Walbro equivilant of it if it will do the job?
Ive had a search through and found different ppl are on different levels with diff pumps but can't see if the Bosch 040 would make that power level ok (with injectors etc to suit obviously).
Thanks
Jaz
https://www.sau.com.au/forums/topic/152653-fuel-pump/
Hey peeps
Thanks
Jaz
The 040 would be fine for the power level you want to achieve or you could get the 023 (same size as 040 and still direct intank replacement) but they flow more.
Im against what TO4GTR said about the 040 cause i've had nothing but problems with the 3 brand new Walbro's i've had in 2 different cars but thats just my opinion.
At the end of the day its your choice what you go with but the 040/023 is fine for the power level your seeking and i think the part number for the Walbro equivalent is the 341 :happy:
GMB
https://www.sau.com.au/forums/topic/152653-fuel-pump/#findComment-2839685
Where can you buy Walbro pumps at a decent price from?
You can get 040's for under $250, are Walbros much more expensive?
There are a few sellers that stock Walbro pumps and they are around the same price of the 040 (depends on where you buy from) although you can get cheap Walbro pumps on EBay :happy:
https://www.sau.com.au/forums/topic/152653-fuel-pump/#findComment-2839690
Plenty of topics about fuel pumps under the search function, plus if your that affraid of mounting isues, get direct intank replacements, for a little more cash, and reliable as well. IE: Tomei direct replacement, at nengun.
https://www.sau.com.au/forums/topic/152653-fuel-pump/#findComment-2839751
Andrew sells Walbro 500hp pumps for 150 or so.. Check out the sponser section..
heres a link: http://www.skylinesaustralia.com/forums/in...p?showforum=123
I bought one, but havnt installed it yet..
I've heard alot about the DENSO intank pump they're based on the tomei pumps i think.. easy fit in R33 but a bit pricey.
https://www.sau.com.au/forums/topic/152653-fuel-pump/#findComment-2841197
    • http://calfinn.com.au/product/1500kg-standard-trolley-jack-cj-2t-c/1500kg-standard-trolley-jack-cj-2t-c   I have this and fits under a S3 33 GTR with no issues. Purchased in 2009 and not one issue. It was $950 back then. Not cheap but something so important isn’t worth cheaping out on.
    • Just trying to get my head around this. At 5psi of boost, you turn on your wmi pump, and then you're using a 3000cc injector, to allow flow upto the actual engine, where you have your 6x200cc injectors and a 500cc injector. If the above is correct, what advantage are you obtaining by having the 3000cc injector blocking flow, is this just incase a line breaks between that injector and the motor you can stop flow immediately? Or are the 6x200cc and 500cc less injectors and just spray nozzle?
    • Welcome! New member myself, but I had an R33 back in 2002. Best advice I could give, based on my experience: if you're running the factory turbo, be very conservative with boost. I made the mistake of just fiddling around with the boost controller and cranking the boost for fun, and the end result was my intake pipes popping off frequently from the constant deluge of oil that was being blown into the recirc by the stressed-out turbo, which itself was siphoning oil from the engine and farting it out both sides of its centre bearing (or something to that effect). If I could do it all again, I would have gotten a new turbo and had a tune dialled in professionally and then just left it alone! Funny you mention the metal shavings in the gearbox, as I had the same thing - the probe plug (magnetic drain plug, essentially) would come out caked with shavings. At least it was doing its job. Not sure if that's just sacrificial wear and part of the deal, or if my gearbox was shagged, but I wasn't abusing it. Enjoy the R33 - they're a dying breed, and if they weren't $35k+ on CarSales in Queensland, I might have picked up one of those again, instead of the 370GT I own now (though I'm loving the 370GT, that big 3.7L V6 just hits different).
    • Howdy folks. I owned an R33 back in 2002, which was thoroughly beyond my capacity (financially speaking) to maintain/insure, so we parted ways in 2004. Fast forward 21 years (to literally yesterday, in fact) and I'm now the proud owner of a 2007 V36 370GT. I'm happily surprised by how much power the VQ37VHR makes, compared to the RB25DET, considering the latter is turbocharged. I had planned to add a turbo at some point but I'm on the fence about whether I'll even need it (though I do love the sudden onset of extra torque). Any other 370GT owners around the traps, I'd love to hear about your experiences with this car (good and bad).
    • Perhaps the answer is... more jacks!* *proper jacks must be used.
