  • Replies 44
Steve You Smell. LOL.
I still have to come back to your place and get the compliance papers from your work.
Im a slack/ lazy boy.
Will see u out at the BSM cruise on the 4th. Looking forward to seeing u there mate.
Brenton.
P.S. there have been some slight changes to my car since u last saw it hehehehe
hey nisswreck,
im after a series 2 grill 96 model and a drivers side power window surround
not the whole assembly with switches just the long plastic bit,
pm me with some prices and availability
thanks
I'm pretty sure Andrew(Nightcrawler) on here in SA has one, prob with piping and all! You should hit him up a PM!
Actually I'm pretty sure that he doesn't have it any more. If memory serves me correctly Prof_dls bought his off of him & put in on the 33 he had before it was written off. Just happend to come up in coversation when I saw him at his place after the accident.
Could I also please be PM'd with a quote for a R33 S2 interior rear view mirror & for a passenger door attaching loop (I don't know it's proper name, the part where the door latches to the body) & a drivers side door trim. All need to be in good condition to be worth while for me.
Cheers
Edited by JazzaR33
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
