Asking people what type of clutch they use ?
Cost of the clutch ?
Labour cost's ?
Rebuild cost's ?
And lastly , where did you get it done ?
sorry dyno results (rwks) would also be worth a mention
all comment's welcome
thanks
Michael :P
https://www.sau.com.au/forums/topic/152881-what-clutch-do-you-use/
I have a exedy twin plate which needs rebuilding or replacement.
Have spoken to extreme clutches (adelaide clutch services) already by the way.
Just checking out other options and opinions. :P
Nismo have stopped making the G Max series clutches. From the success of the Nismo Copper mix single clutch which is the strongest single clucth available that can handle 420 PS. Now Nismo have decided to make the Twin Plate copper clutch to suit most nissans. Rated at 640PS the NISMO Super CopperMix is the highest performance model on the clutch system line. It uses a copper mixture for the clutch disk. The CopperMix is able to handle high horsepower outputs & transmit the all the power to the wheels
Nismo twin plate for BNR32
$1500
exedy 5 puck ceramic
had full faced ceramic extreme, very good streetable clutch. held 205rwkw for 3 years of bashing.
why not do it yourself? i'd help someone. easy job, just needs two people. f**k payin some bastard hundreds when he'll also take your car for a hammer!
Edited by Ryanrb25
I dont have the space to do it myself and wouldn't know where to start.
I have been talking to Jason who used to work at united subaru in town (he owns a 32GTR vspec s"2) and he lives just around the corner from my work.
He is offering to do the job with a cheaper labour price than where the car has been before(mates rates),
and seems to know his stuff. Might take a bit longer than a workshop but that is alright because I wont get the bulls#@t dribble that I seem to get elsewhere.
Because the car makes close to 300rwks I am been told to keep to the twin plate item's.
My 32GTR has the 33GTR box in it because it was one of the last 200 made.
The car has the pull clutch mechanism which has linkages added to convert it to a push type in the bell housing and these will come out and be available at a later stage for some one to pick up (worth $200 secondhand) Might suit a 33GTR owner. :(
Thanks for the offer Ryan if that is what you are saying but after mondays crash, I will have to avoid heavy lifting of any kind for a few month's . Dont want to inflame the torn disc in my lower back from previous accident. :P
Jason from greenline.jp supplied me with my OS Giken twin plate rebuild kit (Kit A), was delivered to my door within 7 days of payment/order for just over $800 ($804 or something)
I then had the guys at ACS/Extreme machine my flywheel and the mounting surface for the clutch cover for under $80 same day service
The twin plate came with a gearbox I bought, and install has been $250 in past, waiting to see what it will be this time as is getting done this week.
I would email greenline and tell them the exact model Exedy twin plate you have and see if they can source a genuine rebuild kit for you.
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
