How rude , can we just get normal sau stickers? , do you still own a r32 ben??
Refer to above post about stickers old boy and "technically" I still own a 32 but it doesn't include an R in its name :ph34r:
  • 3 weeks later...
haha. seen a few skylines about lately. A R33 from memory, cant remember, but it was black with a front lip that used to be blue and is now black. If that makes sense. It also had dark tint. Looked pretty good none the less. It was in a carpark, i won't say where though.
spotto !!! r33 custom plates ( not sure if a can post plate numbers on here ) maroone / burgandy ? in exeter trying to race me then once i back off he flow past then pulled up in a hurry some nast black smoke from exhaust i did see :(
( sorry couldnt stop if ur reading this but was late to drop my car off lol )
    • Not sure the US can import anything other than the C34 Stagea's, but if you can and you need to to tow, DO NOT under any circumstances get an M35 Stagea. If it is just as a family car and your country/state allows it, absolutely and definitely get an M35 (3.5L if possible as it is effectively a 350Z) over a C34.
    • Punch your VIN (nm35-xxxxxx) into Amayama.com You can see everything there quite easily.
    • Thanks for that, I'll check it all out. I can always do the brakes last anyway if its a problem.  The 16's are super cool, if they do fit I'll cruise around with them for a bit.
    • Well, that's kinda the point. The calipers might interfere with the inside of the barrels 16" rims are only about 14" inside the barrels, which is ~350mm, and 334mm rotors only leave about 8mm outboard for the caliper before you get to 350, And.... that;s not gunna be enough. If the rims have a larger ID than that, you might sneak it in. I'd be putting a measuring stick inside the wheel and eyeballing the extra required for the caliper outboard of the rotor before committing to bolting it all on.
