https://www.sau.com.au/forums/topic/152995-new-shots-of-my-black-350z/
You enjoy Vignetting doncha!
Geat pics :)
hahah thanks. Yeah it works well in these types of shots with the car as the focal point. I picked up on it a bit while watching Top Gear.
Nice photos man.. :glare:
How do you get them so good?
:) Photoshop helps a lot mate, tuning, levels, curves, hue, etc.
Can’t wait to get a DLSR & pump out some better shots later on in the year (especially night shots). My current camera just has way too much noise (not the sound form).
Checked out your DA account, your sig pic is now my desktop background. Love the contrast and brightness in your photos, really makes the car stand out, also the lighting effects... or is it a gradient in the corners... however you achieved it looks mint :)
And also convinced me of exactly what I want my next car to be *drool* end of this year fingers crossed and its 350 time!
Awesome pics man.
Nice photos. Looking to get some new wheels for the car? Would look even better then :laugh:
Thanks, yeah I’d love some Volks but that’s a fair bit of $$$$ I don’t have, saving for holidays at the moment. I actually don’t mind the stock rims, before I bought the car I thought I’d def change the rims just looking at stock shots online, but they’re actually not bad in real life, so they’re probably going to stay on for some time.
What is the current camera you Use....The shots are Noice Man :P , very professional indeed
Thanks man, using a Dimage X60, POS compact digital camera IMHO, the shots it produces are so faded & have too much noise, if it wasn’t for Photoshop I wouldn’t be able to produce these shots with this camera. Can't wait to get a DSLR one day.
  • 2 years later...
    • Before all the EFR fan boys come in, have a look at: https://www.garrettmotion.com/racing-and-performance/performance-catalog/turbo/g-series-ii-g30-825-58mm/ It also comes in a T4 1.06 divided housing. I would dare say if you want response & also decent power, this thing would chop.   AND apologies, just re-read your post, you've already bought the turbo... whatever you do, make sure you stick with divided housing and proper twin scroll manifold.
    • People have got to stop doing that. ShatGPT is not a search engine. It is a hallucination factory.   I also would recommend the 1.05. The .83 will "work" for you , in that it will be more responsive, but I think you'll find that it won't be anywhere near as good running it out to 8000rpm as the big housing will be.
    • Decided for the first time ever I would tow my car TO the track day on the same working theory as bringing tools and spares "if I have it I wont need it, but if I leave it behind i will 100% need it" all setup and ready to go out and try these A050 for the first time First session showed I needed to stiffen up the dampers a touch but still managed a few 1:21's without much effort. things were looking good. Came in a dropped the tyres down  to 26/28 as they had gotten to 35/33C from 22C cold The first lap of session two I managed to drop into 1:20's. Then in the second lap into the second session. Coming into T3 and I suddenly lost brake pedal followed by some huge rear end vibrations and scraping sounds. Got it back into the pits after session ended and found this. in the attached video, all of the wobble is in the hub its self, wheel is mint, and bearing feels tight. lKXLqpd - Imgur.mp4   Deciding it was a bent spindle I tried to find bearing/hub assembly locally but was unsuccessful so it was loaded back onto the trailer i luckily brought it on to drag it back home
    • 1.05 you’ve gotta let it breath
    • You have to continuously fill it to avoid dry running. Personally the transmissions I've serviced have never been bad enough to justify doing this because it is definitely a pretty complicated and somewhat risky procedure compared to simply draining the pan, measuring what came out, then refilling with the exact same amount.
