As Title R33 series 1.5 wrecking whole car
Although car is pretty mangled will do front cut for $4000 or
Engine, gearbox, loom, computer for $3500 or
Complete engine with turbo $2000
Gearbox. manual $1500
DIFF $450
Front seats $300 pair
complete Back seat $200
Dash speedo / klm etc complete $200
Doors $200 each
Power window motor $100
RH Taillight $125
Front brake calipers $400
Steering rack $ 150
17 inch wheels - $500
Airbag / steering wheel $150 (not great condition)
Will sell wreck for $6000
IF NOT ON THE LIST ABOVE LET ME KNOW WHAT YOU NEED AS CAR IS STILL COMPLETE.
Will put pics up in next few days
pm for more details
NOWRA NSW 2541. but willing to post / courier at buyers expense.
Edited by DRIFTER
https://www.sau.com.au/forums/topic/153055-wrecking-r33-gtst-series-15-2-door/
DIFF $450
Doors $200 each
RH Taillight $125
Steering rack $ 150
pm for more details
Hello, i need the following prices for a manual conversion to my car thanks
Flywheel
Manual Pedal assembly
clutch Master
Clutch Slave
Manual Tailshaft
Bell housing bolts
Speedo drive
Gearbox cross member with mount
Thanks
Flywheel
clutch Master
Clutch Slave
Manual Tailshaft
Bell housing bolts
Speedo drive
Thanks
whole lot for $500
but don't have the bolts or the speedo drive at the moment.
  • 11 months later...
DIFF $450
Doors $200 each
RH Taillight $125
Steering rack $ 150
pm for more details
Nath, Please call me on 0424 406 932
Dan.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
