New 4 door round...
Guest 382 GZV - 4 Door R33
G'day,
Just thought I'd introduce myself (after checking out SAU a bit). May have seen me round a bit - live near UQ.
After having completely broken the auto transmission in my N13 Pulsar for the 2 time in 16 months, I figured I needed something sturdier. I found nirvana at the end of Feb after waiting for over a year :)
I'll try posting a pic of my car on, it may be too big though. It's nothing flash, just the only photo on my computer atm. I wanted something I could keep for a while and since I'm already married (only 20 though) and kids may be sometime in the future, it had to be a 4 door.
Anyways, if you want, say hi when you see me and lemme know what's good and what's not with mods as I am planning on doing something year.
Steve
PS. Skidpan day was great slip; will defnitely be doing the next one :P:D :D
https://www.sau.com.au/forums/topic/15314-new-4-door-round/
Hi Steve, good to see some more 4 doors getting around :(
u might have seen me on sunday, i own the silver r32 4 door.
if u need and help or advice with mods give us a yell, my dad owns a r33 4 door so i've been down that path before :D
https://www.sau.com.au/forums/topic/15314-new-4-door-round/#findComment-312964
Mountains are mad :-) Is it true that guys drift around corners on the mountain so it's pretty slow going??
What are you getting done to your car slip?
Hey, I found driving a skyline is a bit different to driving a Pulsar. I use to have to sit flat footed everywhere round town in the pulsar. When I got the skyline I was in the habit of flattening the accelerator (had to use a fair bit of braking to keep it in check). So I was only getting 280 - 350 a tank! :-( At least it is better now...say 460 a tank. At least I can save for go-fast bits now.
:):D :D
https://www.sau.com.au/forums/topic/15314-new-4-door-round/#findComment-316267
Welcome GZV...
I have recently had my first baby... thus traded in my beloved DOHC Jap-spec VTEC Civic (15 sec quarters) for my black 4 dr manual, too. Turbo cars are certainly different in their power delivery. Civic made more and more power through the rev range - right up to 8700rpm! R33 gives a couple of BIG shoves, one at around 3000rpm and the next at 5500rpm. With the boost wound up a little to 10 psi I'm pretty sure the standard computer is overfuelling and retarding the timing - from what I've read here in the forum - causing a flat-spot btwn 4200 and 5500rpm. (Maybe MicK51 has a few ideas!) Hoping to get that sorted one day - hopefully soon - but probably when my boy goes to school (in 5 years!!!) and my wife goes back to full-time work!!! Who knows...
Will post a foto here of my 4dr in next couple of days!
Would love to do something on the track. Have taken Honda out b4 but not the 'line yet! Just for the hell of it...
iijj
(North of Bris)
https://www.sau.com.au/forums/topic/15314-new-4-door-round/#findComment-316328
    • f**king around with the bro
    • Ludenham   44.2 tops day no issues
    • Then today, I went to visit a man with an r33 hat Peter and Road and Race sorted the alignment. As it is being set up for general track/hillclimbs etc it has a heap of caster (7o), less camber than I am used to (1o front and 2o rear, as the caster looks after that in turns without the braking downsides), 3mm front toe out and 0 toe rear. Will see how that goes and track tyre wear to see if it does need more camber, but adjsustment is also limited with nismo arms and adjustable bushes at only 1 end. It does have a bent inner tie rod on the driver's side front but as it came up within spec I'll just leave that as is. So, that is getting close to my chapter of this story....could of tidy ups then a shakedown in early October before it finds a new home.
    • So, it went to Unigroup for a run in and tune on Friday, everything went (generally) well. In terms of fixes, the engine was good and there were no leaks. It needed plugs (I hadn't checked them because the coil pack cover was on a new engine and I couldn't imagine they weren't new.....but turns out the temporary plugs to just keep it sealed up were in there.....new plugs gapped to 0.8 and it was fine from there. Also, there was a little preload on the clutch slave which caused some slip. I haven't had the box off so I don't know what the clutch looks like; my guess it is brand new and the pedal had not been adjusted....backed that off a bit and it held fine. Last thing will have Dose crying....the idle especially when cold is a bit difficult between the cams, forward plenum, atmo blow off valve and an 80s air management system. It is fine when hot but a little uneven when cold, will see if I can sort or at least improve that one cold morning. Other than that, tuning went fine. It made 245 but was pulled back to 227 which 2 opportunities to improve in future. 1. The factory CAS is not great and was jumping around at high RPM, so Mark took 2 degrees out up top (that is why it stops making power and lost 20kw). Very safe this way and the extra power is available but will require a more modern ECU and better cam (or even better crank) sensor 2. The 2871 in factory housings is very big for a low mount, and the internal wastegate is too small, so it was creeping from mid range all the way to redline....the duty cycle on the boost controller is turned down a little for safety. That is much harder to fix, it would need a large external gate and that would require a whole bunch of other changes, so it will go as it is for now. It feels nice and healthy and safe, so should be good for about a billion laps like this.
    • what sort of caliper are they? If they are a slider and you gave everything a good clean, you might need to regrease the pins. My guess though is they will come good after some abuse as suggested above
