Anyone heard of Morel Hybrid Ovation 6 inchers splits?
I can get some ultra cheap so I need to know if they are any good.
Heres a link to them.
Also, What do you think of the new series Alpine PDX2.150 to drive them?
Thanks for your input. :(
https://www.sau.com.au/forums/topic/153170-morel-splits/
These are third from the top of the range morel speakers..
They generally sell here for around 600 mark i beleive. Or was it the integra series for that much??
How much are you gettin them for?
Edited by siddr20
https://www.sau.com.au/forums/topic/153170-morel-splits/#findComment-2854845
  • 1 month later...
finding out for you now mate, will you seriously buy a few?
http://www.fhrxstudios.com/ is where i am getting them from.
Why are you quick to doubt me? If I said I am getting them I am getting them.
Edited by Pauly33GTS-t
https://www.sau.com.au/forums/topic/153170-morel-splits/#findComment-2976783
Im not doubting you, its just that the distributor sells to the public direct at pretty much wholesale rates.
If anybody is selling them cheaper, well id be asking WHAT THE HELL, considering they went from $1200 retail to $535 and now ur saying ur getting them for $400+.
https://www.sau.com.au/forums/topic/153170-morel-splits/#findComment-2979775
ok chris rogers, i deal in 2 or 3 things at a time for me, and ill turn up the volume dont u worry about that... in dB.
I simply wanted your opinion on these splits as I am going to use them for possibly the front and back or just the splits at front and same woofers (6ers) in the back parcel shelf. i didnt want a OMG WHAT GET ME MERCHANDISE YOU c**t!.
https://www.sau.com.au/forums/topic/153170-morel-splits/#findComment-2990793
Cos this guy thinks he is cool telling everyone he can get cheap stuff.
But what he doesnt realise, Chris and I both own shops and we have access to the stuff.
Hey guess what Pauly i can get stuff cheaper than you, so instead of buying over the net how about come get it local ill match any price FHRX can dish out.
https://www.sau.com.au/forums/topic/153170-morel-splits/#findComment-2991187
I just checked with FHRX and they sell Morel for the price printed on the pricelist on their website. Marty stated that they sell them for this price because the retail is in grey next to them.
On that note, this topic is now closed. Let's leave it at that.
Everyone take a deep breath and think about what you type before you hit the 'add reply' button next :mellow:
https://www.sau.com.au/forums/topic/153170-morel-splits/#findComment-2991225
    • Well, this is probably where a wiring diagram and a multimeter come into play.
    • I can say to anyone thats doing this; having done a number of R clusters; just be careful if its an unknown cluster.  It takes a bit of force to pull up; but if it feels excessive then its probably stuck. I've had this and pulled the entire hair spring out; and I can tell you; its not easy getting the correct spring replacement with the correct inner diameter and winding. In my case someone had used some sort of adhesive to stick it to the spindle and it pulled the whole spindle out; which the force seperated the hairspring from the spindal and caused it to deform.  You may have to clean it (IPA); or in my case if i'd known i should have used some sort of solvent on it.  Also check out Cruizin Central on eBay. He does all sorts of dials; and you can email him with any custom designs you want. So if you want like certain logos etc...he'll send you a mock of what it will look like then you accept the order and he'll take care of the rest. Fantastic dials and he can do basically any design you want.
    • Have you confirmed its the actual axles? Also the wheel bearings that mount on the hubs to hold the axles wear out. I replaced mine as they got play in them. It sorted my play issue.
    • Ive converted a few clusters for the R33 with 320km/h dials. On the back there are some pads which can be bridged or unbridged (using solder or wick braid) to calibrate it. There is one bridge which is for MPH <> KPH; and there are combinations of bridges to offset it. There is probably a diagram  For example; this is my conversion for a 180km/h dial to a 320km/h dial (I put custom GT-R dials on it with the GTS25t layout) If you have J2 soldered (assuming the S clusters have a similar config to the R clusters); you may need to remove that solder
    • Back on topic 😉, these are some of the notable pages from the booklets that are supplied with each weekly parts update. I never knew the BNR32 test mule car had an S13 Silvia front end... *Edit: On closer inspection the test car still had the R32 body, but only the front end had Silvia panels etc.
