Hi dudes, I have just finished installing a JVC KW-AVX700 unit into my R32. JVC have built in a "feature" that won't allow a viewable playback unless the handbrake is applied. However, it is also stated that the warning won't appear unless the handbrake and JVC unit are physically wired up to eachother.
The instructions say the following:
"If the parking brake is not engaged, "Parking Brake" appears on the monitor, and no playback picture will be shown. This warning appears only when the parking brake wire is connected to the parking brake system built in the car."
The funny thing is that I didn't hook the wire to the handbrake so the warning should be disabled. Furthermore, I am still getting the warning even when I do apply the handbrake.
Any ideas? It would be sh*t to have an incar DVD if you can only watch it when the car is completely stationary....
https://www.sau.com.au/forums/topic/153424-kw-avx700-dvd-playback-issue/
your park brake sensor on the unit should be looking for a negative signal.
Just ground that wire from the head unit to a good source of negative ( chasis) and you should be fine.
righto... i earthed the park brake wire and now it's fine... thanks all for your help...
..phew!!
i know.... i knew there had to be a way around it... just glad it was so simple... imagine having the unit without being able to have the video clips running while your driving... or going for a trip with your mates and telling them they could only watch the display at the traffic lights... pfft...
thn imageing being distracted by the same uint and running over a pedestrian. thats the reason it is there :P
LOL i know its not funny but this guy got the sack from JB-HiFi for not connecting it to the park brake signal... we use to make customers sign an document if they wanted it done with the wire striaght to negative, it said something like "we are connecting this to the park brake signal wtf you do with it after is your business" something like that to keep us from getting sued in an "unlikely" event just like Chris stated...
If it is an indash monitor you might want to hook up a switch somewhere so the PoPo cant get you for it too.
bit of an overkill don't you think....? just risk it and turn it on to radio if you get pulled over... fairdinkum...
ive got a miriad of switches i call 'cop switches' that i just bang to the up position when i go past cops... saved me a few times...
the best thing to do is to get a two phase switch and ground one end, and send the other to the hand brake so if you ever do get shit about it, just flick the switch to handbrake mode... sup to you though...
got a diagram to show me...? Do i still ground the handbrake wire from the back of the HU or do i rig it up properly to the handbrake then use the switch to ground it while the handbrake is off??
that diagram took me 2 hours, so i hope you appreciate it!
go to jaycar, DONT SHOW THEM THAT, they will laugh at you, tell them what you wanna do and what kind of switch you need, then wire the ground from the head unit to the single input, then ground one of the outputs, and wire the other to the ground cable on the handbrake...
finding a suitable place for the switch is always fun... i got 5 wittle ones in my drink holder :ninja:
I just realised that I didnt even attach the hand brake wire to anything.. and it plays as normal... what the..?
But the only problem is, that there's no power running to it when the car's turned off. Therefore.. the clock resets, and the CD/DVD starts from the begining..what the?
you've got your 12V+ and your acc wires mixed up... when you turn your car off, it kills the 12V+ line that should always be on, and uses the ACC line as battery backup, which is obviously off now...
take it out, swap em over and you should be fine...
    • Hey Dave, welcome aboard! Good to see another soon-to-be Stagea owner here. The wagons are awesome — plenty of space, still got that Skyline DNA, and loads of potential if you’re into mods. Definitely post up pics when you get it, everyone here loves seeing new builds. What model/year are you looking at?
    • See if you can thermal epoxy a heatsink or two onto it?
    • The other problem was one of those "oh shit we are going to die moments". Basically the high spec Q50s have a full electric steering rack, and the povo ones had a regular hydraulic rack with an electric pump.  So couple of laps into session 5 as I came into turn 2 (big run off now, happily), the dash turned into a christmas tree and the steering became super heavy and I went well off. I assumed it was a tyre failure so limped to the pits, but everything was OK. But....the master warning light was still on so I checked the DTCs and saw – C13E6 “Heat Protection”. Yes, that bloody steering rack computer sitting where the oil cooler should be has its own sensors and error logic, and decided I was using the steering wheel too much. I really appreciated the helpful information in the manual (my bold) POSSIBLE CAUSE • Continuing the overloading steering (Sports driving in the circuit etc,) “DATA MONITOR” >> “C/M TEMPERATURE”. The rise of steering force motor internal temperature caused the protection function to operate. This is not a system malfunction. INSPECTION END So, basically the electric motor in the steering rack got to 150c, and it decided to shut down without warning for my safety. Didn't feel safe. Short term I'll see if I can duct some air to that motor (the engine bay is sealed pretty tight). Long term, depending on how often this happens, I'll look into swapping the povo spec electric/hydraulic rack in. While the rack should be fine the power supply to the pump will be a pain and might be best to deal with it when I add a PDM.
    • And finally, 2 problems I really need to sort.  Firstly as Matt said the auto trans is not happy as it gets hot - I couldn't log the temps but the gauge showed 90o. On the first day I took it out back in Feb, because the coolant was getting hot I never got to any auto trans issues; but on this day by late session 3 and then really clearly in 4 and 5 as it got hotter it just would not shift up. You can hear the issue really clearly at 12:55 and 16:20 on the vid. So the good news is, literally this week Ecutek finally released tuning for the jatco 7 speed. I'll have a chat to Racebox and see what they can do electrically to keep it cooler and to get the gears, if anything. That will likely take some R&D and can only really happen on track as it never gets even warm with road use. I've also picked up some eye wateringly expensive Redline D6 ATF to try, it had the highest viscosity I could find at 100o so we will see if that helps (just waiting for some oil pan gaskets so I can change it properly). If neither of those work I need to remove the coolant/trans interwarmer and the radiator cooler and go to an external cooler....somewhere.....(goodbye washer reservoir?), and if that fails give up on this mad idea and wait for Nissan to release the manual 400R
    • So, what else.... Power. I don't know what it is making because I haven't done a post tune dyno run yet; I will when I get a chance. It was 240rwkw dead stock. Conclusion from the day....it does not need a single kw more until I sort some other stuff. It comes on so hard that I could hear the twin N1 turbos on the R32 crying, and I just can't use what it has around a tight track with the current setup. Brakes. They are perfect. Hit them hard all day and they never felt like having an issue; you can see in the video we were making ground on much lighter cars on better tyres under brakes. They are standard (red sport) calipers, standard size discs in DBA5000 2 piece, Winmax pads and Motul RBF600 fluid, all from Matty at Racebrakes Sydney. Keeping in mind the car is more powerful than my R32 and weighs 1780, he clearly knows his shit. Suspension. This is one of the first areas I need to change. It has electronically controlled dampers from factory, but everything is just way too soft for track work even on the hardest setting (it is nice when hustling on country roads though). In particular it rolls into oversteer mid corner and pitches too much under hard braking so it becomes unstable eg in the turn 1 kink I need to brake early, turn through the kink then brake again so I don't pirouette like an AE86. I need to get some decent shocks with matched springs and sway bars ASAP, even if it is just a v1 setup until I work out a proper race/rally setup later. Tyres. I am running Yoko A052 in 235/45/18 all round, because that was what I could get in approximately the right height on wheels I had in the shed (Rays/Nismo 18x8 off the old Leaf actually!). As track tyres they are pretty poor; I note GTSBoy recently posted a porker comparo video including them where they were about the same as AD09.....that is nothing like a top line track tyre. I'll start getting that sorted but realistically I should get proper sized wheels first (likely 9.5 +38 front and 11 +55 at the rear, so a custom order, and I can't rotate them like the R32), then work out what the best tyre option is. BTW on that, Targa Tas had gone to road tyres instead of semi slicks now so that is a whole other world of choices to sort. Diff. This is the other thing that urgently needs to be addressed. It left massive 1s out of the fish hook all day, even when I was trying not too (you can also hear it reving on the video, and see the RPM rising too fast compared to speed in the data). It has an open diff that Infiniti optimistically called a B-LSD for "Brake Limited Slip Diff". It does good straight line standing start 11s but it is woeful on the track. Nismo seem to make a 2 way for it.
