Not after the cost of fitment compared to Garrett T28 replacements :miner:
Standard Rb25 turbo's have ceramic turbines aswell as the standard GTR turbo's and will fail.
No ceramic turbine should be considered an upgrade as sooner or later the turbo's will be off the car again.
I wouldnt bother.
I'm have it for free from my mate. My concern any advantages if we campare from standard GTR
free or not, its a very bad idea.
Flanges are different, there are turbos designed for the RB26 that will outperform a twin RB25 turbo setup day in day out, and without the risk of failure
get the RB25 turbos, then sell them.
  • 4 months later...
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
