Not sure what others would charge but its not rocket science.
Requires access to a datalogit and a little loom fiddling which is bugger all. I'd say in all, 30mins to 1hr max in labour providing the bloke doing the work has half a brain. :)
  • Replies 162
but Dan tells me that they can all be stuffed in behind the original ECU
I havent done this yet because im waiting to get it tuned then ill install it properly
:) you make me sound brutal, seriously though my Field harness was literally folded in half with the excess wires sliding into the cavity behind the ECU.
so how much beer would it cost me to get the 26 pfc installed in my stoopid 25t then ?>
cuase otherwise im going to save up an get me a emanage ultimate...laaawt of saving though
a faq for the emanage would be very useful
its not a matter of beer
but a matter of changes, adaptions and known "gotchas" when using the rb26 PFC on rb26
the biggest known gotcha is no VCT support at all
if you have aftermarket exhaust cam gears then this point is void.
in summary;
you need to copy the stock rb25 maps onto it (need datalogit)
need to parrell up the afm signal (single afm into twin afm ecu)
need to parrell up the 02 signal (single 02 into twin 02 ecu)
rescale injectors down to rb25 size (unless u have larger ones)
but there are plus sides;
djetro option
working air temp support
can use twin or single afms if u want (both work)
can use twin or single 02 sensor (both work)
and u can buy it new from most apexi distro's (nengun comes to mind) for $890 delivered
ive been thinking about buying a 26 pfc for a while now
and just trying it on my car as i have datalogit
but the main worry is the wiring loom changes
i guess i could open it up and make the changes
ap engineering style
how many would be interested in a custom "ap engineered" style PFC to suit their rb25
it would mean however no working VCT support. if you have aftermarket exhaust cam gear then this problem is void.
it would involve me buying a 26 PFC and then making some changes to suit your rb25
Might be worth checking out if jaycar has anything suitable to trigger the vct from an rpm signal.
I know I've said that before paul but surely some one on this site should be able to easily sort somethign?!? :S
http://www1.jaycar.com.au/productView.asp?ID=KC5378
:pirate:
So hows the vct work?
Just above idle it enables, then at the preset 4700rpm for example it disengages again.
This increases overlap during the mid range to aid turbo spool and mid range torque, over 4700rpm it turns off as to reduce overlap and prevent reversion etc due to backpressure which by doing so helps top end.
yep
i had mine turn off at like 1900 for a bit of fun
and the car was sluggish and drove like a bucket of poo
thats not to say it would do the same withit complelely off
I think you would need 2, one set at say 1,200 rpm to turn it on and one set at say 4,700 rpm to turn it off. You could install them at the ECU and use the same pins in the ECU plug as the standared VVT. Pretty simple actually.
:) cheers :huh:
Clint32 built up his 'hardcore' r32 gtst track car.
Was awesome to look at.
He purposely retained the vct and 9:1 comp ratio and still made the power he wanted. GT3040 on the engine dyno it pulled 580hp at 26psi.
    • You just need to remove the compressor housing, not the entire turbo. I would not be drilling and tapping anything with the housing still on anyways.
    • So, I put my boat on a boat. First of all, I'm going to come out and say it. Why is Tasmania not considered a holy goal, an apex that all road-legal modified cars go to, to experience? This place is an absolute wonderland of titanic proportions. If people are already getting club runs for once in a lifetime 30 person cruises to Tassy then I've never seemed to see it. It is like someone replaced the entire place with an idyllic wonderland for cars, and all of the people living there with paid actors who are kind, humble, and friendly. Dear god. After doing a lap of almost all of the place I've found that it's a great way to find out all of the little things that the car isn't doing quite right and a great way to figure it all out. All in all, I drove for 4 hours a day for a week and nothing broke. I didn't even need to open the engine bay. This is by all means a great success, but it has left me with a list of things to potentially address. I also now have a 3D printed wheel fitment tool which annoyingly hasn't got any threads in it to actually assemble it. I might be able to tape it together to check the sizing I actually want to use, but it'll likely involving pulling the shocks out to properly measure travel at least at the front, and probably raise the car while I'm at it, at least in the rear. I scraped on quite a few things and I'm not sure how else to go about it. I was taking anything with a bump at what felt like 89 degree angles. And address those 10 other tasks. And wash the car. God damn it is dirty. And somehow, the weather was perfect the entire time - And because I was on the top of Mt Wellington it turns out it was very much about to freeze up there. I did something I typically never do and took some photos up there in what must have been -10 and the foggy felt like suspended ice, rather than mere fog. If you own a car in Australia, you owe it to yourself to do it.
    • Damn that was hilarious, and a bit embarrassing for skylines in general 😂 vintage car life ey. That R33 really stomped. Pretty entertaining stuff
    • Hi, I have a r32 gtr transmission. Does any of you guys have an idea how much power it will hold with the billet center plate and stock gearset? At what power level and use did yours brake with or without billet plate? Thanks, Oystein Lovik
    • Saw this replica police car based on a Mitsubishi Starion XX parked next to a 'police box' (it's literally a box) in Hirohata, Himeji City in Hyogo prefecture the other day. It's owned by Morii-san who is a local Mitsubishi Starion enthusiast. According to a local radio station blog post, he always wanted to make a police car himself based on ones he saw in his favourite Manga comics.  As it's illegal to modify a car to look like a police car and drive on the road, Morii-san tried many times to get permission from Aboshi police station headquarters nearby. They refused initially by after they got tired of that they granted him permission. However, the car can only be displayed on private property and obviously can't be registered as long as the police livery is present. The car was completed at a cost of 1.5 million yen (US$ 10,000) in addition to the car cost. A location was chosen outside Hirohata Police box where the car can easily been seen from the street. Morii-san has two other Starion road cars, both widebody GSR-VRs.
