Guest INASNT
Originally posted by DJ_L3ThAL
yer i got my powerfc done by ice, and nigel spent ages fine tuing it on ther dyno but still on cold nights and under differnt loads etc i got some pinging, i just noted when this happened and went back as i found new areas that needed fine tuning and we ironed them out within a week, think i onloy went back twice which was awesome considering now my car is 100% ;)
ho did u know it was pinging?? was the knock reading over 60% on the h/c ?
  • Replies 50
this powerfc sounds interesting....
i have not owned or study it at all....although i did test drive an r33 which had one installed... it went nice and hard....
can you tell me how much they cost and where i can find technical info on them?
after using LINK, Wolf 3d, Haltech, seeing what motec can do and studying autronic, i would love to compare.
Originally posted by king_kw13
what are big power mods Al? Is big power mods defined as
- Larger Injectors?
- Aftermarket Cam Shafts?
- Aftermarket Turbo?
- FMIC?
- Big NISMO Sticker?
First three. Forth can be delt with by the apexi, and the fifth by the wanky ricers :P.
The best programmable ecu, is the one your trusted mechanic can tune. No use having a Wolf if he has only delt with a Pfc and isn't able to extract and use all features :uh-huh:.
But if you plan to change the first three items listed above, do the ecu first, as this alone will give you a noticable differance.
my 2c
Good luck with your decision
Guest INASNT
Originally posted by Jay95R33
rs73 - yepp, that's my understanding.
I've heard 'stories' of people pluging in a new PFC and gaining 15rwkw just from the base map it comes with..
Not sure how true this is, but sounds tempting.
J
u may get a slight power increase but the car will be pining off it tits as the fuel maps r based on jap 104 RON fuel
i wish it was that simple that the best ecu is the one your mechanic can tune the best.
Personally i would, and have always had my cars tuned by the workshop the particular ECU company recommended to tune, supply and fit.
Originally posted by rs73
Al,
why you wouldn't wanna change factory IC with FMIC, considering with afm injectors, cam, & turbo?
what would be the factory IC efficiency is, don't think it will be effective for boost above 12 psi.
The original question was: what do i consider big mods to justify a ecu replacement. If you only plan to go as far as a fmic i am suggesting to use a apexi safc to trim the fuel curve. Of course you need to replace that shitty factory ic. If you are planning a turbo upgrade, etc. than a replacement ecu is a priority.
my 2c
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
    • Does that German restaurant still exist in the old place out the NW end of Goulburn? When I say "out the NW end of"...I am really being vague. It was 1997 when I was last there, and the only point of reference I can recall is that it was on the opposite side of the main drag from the big merino. And when I say "opposite side of the main drag", I don't mean "on the main drag". It was either a couple of streets back from there, or might have even been out in the sticks a bit further. Was an old farm building or mill or somesuch. And when I say "the big merino" I might actually be thinking of a completely different part of town, because I just looked on maps and the big bugger is not where I remembered him to be! The food was good, consisting largely of various German mystery-meat sausage/loaf things and kartofflen.
    • So while the second sentence is completely correct and the whole point of the conversation, the first sentence bears consideration. If this bloke is just hoping to throw big turbos on and drive it around, because there are no helpful facilities at all in his tropical paradise** then he likely has zero chance of even knowing what the TP is on the last column in the stock maps, let alone know whether the ECU is operating anywhere near it or past it. So the point is very very moot. And, per what I said before, at stock boost on those turbos, you may well be off the end of the map. **I'm just back from Vanuatu, so I know exactly what small Pacific nations can be like wrt paradise without requisite facilities. But it's not even that simple. I put a high flow on my car and had to drive it around without a proper tune because of the lack of opportunity*** to put the bigger AFM and injectors into it to allow it to be tuned. I had to turn the boost down to less than I had before, and back off the boost controller's ramp, because it was exploring parts of the map that it didn't drive in before, and really couldn't access for tuning on the dyno either, and so was pinging. It was still well within the last column, because when I first**** set up the Nistune on the Neo I rescaled all axes of the maps to give some more space to explore. ***Family dyno was broken ****This was 13 years ago, and the TIM thing wasn't a thing then and so TP would definitely grow when pushing past the stock tune's limits.
