Hi All,
Looking for an easy going, considerate and clean room-mate to share with 2 females (21 y.o and 29 y.o) in a 3 bedroom home located in Preston. The Room itself is unfurnished but the rest of the house fully furnished. Close to train station, Preston market, and approx. 15-20 mins from the CBD. $85 p.w + exp. $340 for bond. We will be moving in on the 19th of Feb 2007. PM me for contact details if interested.
Thanks,
Kylie :)
https://www.sau.com.au/forums/topic/153824-room-mate-wanted/
i will take the 29 year old thanks :P
nah..kidding - u should advertise at universities and tafe and stuff - thats where a lot of the potential roomates are....but be warned - lots of international students might end up calling u gals up....
i will take the 29 year old thanks ;)
lol....we are advertising at other places, but we thought we might try in here as well....see how it goes I suppose ;)
Room mate or House mate, just incase it wasnt clear? :laugh:
lol...House mate...
kyks u know i would, but preston isnt where i wanna b, 2 far around for me
No probs Kam.... :cool:
pick me, pick me!
lol...sure thing Kon, if you want, PM me for contact details then :action-smiley-069:
85 bucks a week?...fark abit expenses......btw does it have carpark....Is this for long term/short term. Do you guys seek all appearances or jst one in particular.......lol. iM interested coz it's time to let my gf know i cbf listern to her craps coz if i can i wud hv stil at home with my parent. So seriously when can i see the place?
Edited by comet
Lets not start an expensive rent debate again please!!!
IMO $85 is reasonable for preston unless the house is falling apart (which i doubt)
    • Yeah well per the video it took 15s for the stock unit to start up....even if I give it a few seconds discount for starting that is at least 12 sec before you get a reverse camera if you are trying to leave a park.  The android unit is way faster, but 2016 for the stock unit is a long time ago in consumer electronics
    • Yea that’s why I said ima test them with multimeter and see the reads.
    • Only at idle. Isn’t a problem when rev it seems.
    • @Haggerty This seems silly to ask, but are you confident in your ability to tune the Haltech?
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
