  • Replies 80
Originally posted by justified2.4
I am interested in the Mines or the Power FC if you still have them, email me: [email protected] or AIM: JCAP Tuning
Thanks.
check your e-mail
  • 2 months later...
Originally posted by tridentt150v
By the way, I did look at your car once, when you were selling it [the white gtst].
I'll be away today.
See your PM
I think you've got my car confused with another, cause mine was silver.
anyway the cluster i have is normal GTST cluster with a Nismo 300km/h Speedo in it. $475
and I also have a standard R33 GTR cluster (fits a GTST) for $300.
I will only sell the cluster as a whole I will not seperate the individual meters.
Originally posted by heifongliu
Hei,  got a mate who may be interested in The MINES ECU,  how much would you go for it .. i live in sydney .., does it have hand controller .. what' the model no .. and the conditions. ..Thanks
The Mines ECU does not have a hand controller. the power fc has a hand controller
What are the mileages on the GTR and GTSt clusters, could you send a jpg to me of each one.
I'd like to talk to you about these. The price is not an issue, just want the best one.
Danny.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
