1992 R32 Nissan Skyline GTS-t M-Spec
approx 213000km
Recently had its major service at 197,000km, in which the following items were replaced:
* Clutch Slave Cylinder
* Timing Belt (Gates Racing)
* Idler and Tensioner bearings
* Water Pump
* Fuel Lines
* Fuel Filter
* Cam Seals
* Crank Seals
* All Belts
* Coolant Flushed
* Gearbox Oil (Redline Lightweight Shockproof)
* Differential Oil (Motul Gear300)
Has a reconditioned radiator with new end tanks (reconditioned approx 6 months ago)
Just replaced the rear rack ends and the rear steering arm balljoints
Front tie rod ends were replaced just after major service.
The car is serviced (spark plugs, oil filter, oil) every 5000km
Religiously looked after by conservative/mechanically sympathetic owner (i.e. car gets driven like your grandparents are driving)
The car made 171.3 rwkw on only 11psi boost
Car has run a 1:03:39 on the Sportsman circuit at Queensland Raceway
Car has run a 1:03:78 on the Sprint circuit at Queensland Raceway
These times were recorded with very little race experience, and i feel there is a lot more potential in the car with a 'good' driver. The car was also only running around 155rwkw at this stage.
Car is registered until July 2007
Exterior Mods:
* Nissan S14a Rims with GoodYear Revspec RS-02 Tyres, in 205/55/16 (tyres approx 50% remaining)
and
* Nissan R32 GTS-t Rims with Bridgestone RE55s (SR Compound) Tyres, in 225/50/16 (approx 70% remaining)
* Rear Wing Removed, and Boot Welded Up/Resprayed
* R32 GTR or GTS-t Type M Sideskirts and Rear Pods
* R32 GTR Front Grille
* R32 GTR Aluminium Bonnet
Interior:
* Nismo Leather Gearknob
* New Leather Gearstick and Handbrake Boots
* R32 GTR Steering wheel
* R32 GTR Drivers Seat
* Autometer Boost Gauge
* Impakt's NissanDataScan Consult Interface
* GReddy Turbo Timer
ICE:
* Pioneer DEH-P4650MP Head Unit (With Remote Control)
* Blaupunkt 200w 6.5" Splits in the rear
Suspension & Braking:
* Kings 'Lows' Springs front and rear (Fitted 26/07/2005)
* Bilstein Shocks front and rear (as above)
* Flying Performance Front Strut Brace
* Generic Rear Strut Brace
* Whiteline 24mm Front and 22mm Rear, Blade Ajustable swaybars
* Whiteline Adjustable Front Camber Bushes (Fitted 26/07/2005)
* Whiteline Adjustable Front Castor Bushes (as above)
* Whiteline Adjustable Rear Camber Bushes (as above)
* Whiteline Subframe Lock and Align Kit (as above)
* Custom made Hicas Lock Bar
* Ferodo DS2500 brake pads front and rear (only a couple of months old - barely worn)
* DBA 4000 Slotted Rotors on the front
* Machined standard Rotors on the rear
* Motul RBF600 Brake Fluid
Engine:
* Flying Performance 3" Front/Dump Pipe Combo
* 3" High-Flow Cat
* 3" Kakimoto Catback Exhaust (extremely quiet)
* K&N Pod Filter
* Custom Heat Shield for Pod Filter
* Heavy Duty Clutch of Unknown Origin
* RB25 Turbo with RB20 Actuator (increases base boost)
* R34 GTT Sidemount Intercooler with Custom Piping
* GATES Racing strengthened Timing Belt
* D2 Fuel Pressure Regulator
* Walbro 255 Litre/Hour Fuel Pump
* GReddy Type S Plumbback BOV
* TurboTech Boost Controller set to 11psi
* Remapped ECU Chip mapped by DrDrift
There's probably a heap of things i've left out, but i can't think of any more at the moment...
if you have any questions, feel free to post them here, and i'll do my best to answer them for you! smile.gif
Here are some pictures of the car from 27.08.2006 (Still looks the same)
as you can see, the car is well looked after, and is probably one of the cleanest around...
and some of the dyno chart:
PRICE DROP! NOW $15200 ONO
Car is located in Brisbane
https://www.sau.com.au/forums/topic/154091-1992-r32-gts-t-type-m-modified-bne/
You say:
Then you also go on to say:
Discuss.
You say:
Discuss.
Lol.. A track day doesn't = a dead car.. I'd be trusting this guy more than say (person B) e.g. some other guy who says he's never been to the track, has few if any service records and claims a bunch of things about how it's babied around. Because person B's car has most likely been thrashed on the street.
There's a difference.. This guy probably changes the oil before and after his track day (maybe) where as Person B thrashes his car most of the week and does bugger all to his car..
Just my 2 cents.
Just my 2 cents.
exactly...
i don't thrash my car on the street, i usually bleed/change brake fluid, engine oil, oil filter, gearbox oil, diff oil, spark plugs etc after a track day, as well as doing an engine oil change beforehand (and i use good quality oils for all of these). When i drive the car on the street, i always warm it up before it sees boost (i.e. it doesn't see boost for the first 10 minutes of driving) and also warm it down for the last few minutes before i stop the car. At the track i warm the brakes, gearbox, diff up and down before and after use. Gearchanges are not hurried and i don't slam it into/crunch gears, as well as rev-matching on downchange (less stress on the gearbox)
There's a big difference between driving a car hard on the track and 'thrashing' the car on the street.
  • 3 weeks later...
It actually used to have a full GTR kit on it (front bar and spoiler), but with the old suspension, one point of the GTR front bar was 2mm too low, and i got defected for that.... so instead of spending $$$$ on the suspension at that time (i spent it later on though :)) i put on the front bar that you see in the photos to clear the defect.
mate the kilometres travelled on this car are no more (actually, probably less) than 99% of R32's and R33's out there that claim to have '80,000km' or '100,000km' on the clock... only difference is, mine is showing the real reading, not like all the dodgey wound back crap out there...
and also, as said in the Ad, i am slightly negotiable, but i'm not going to let it go for something stupid like 11 or 12k like all the dreamers out there expect
Couldn't agree with you more! Anyone who believes a 15 year old Skyline has 80000km is an idiot. Goodluck with the sale, looks clean and genuine :whistling:
Couldn't agree with you more! Anyone who believes a 15 year old Skyline has 80000km is an idiot. Goodluck with the sale, looks clean and genuine :closedeyes:
Agreed only the odd rare example would have k's close to 80k. Id feel happy to know what the car has actually travelled.
    • It is a kunfine Android screen . Does anyone know the wirering diagram of the fuga ??
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
