Really depends what you are after.
I'm going to push upwards of 300rwkw maybe slightly over so I didn't want to hit 280rwkw and realise I should have done those forged pistons. :/
The head has been rebuilt, ported polished, the required angled valve jobs to suit the exhaust and inlet, cc'd & inlet valves deshrouded.
*make sure you get the seat pressure checked as some RB25 heads tend to lack seat pressure causing valve bounce at higher rpm and higher boosts, in other words don't buy it second hand and assume it will be fine*
The bottom end has had everything crack tested, blueprinted & balanced to 1g using a hienz balancer.
Forged pistons & 3 multilayer s/steel head gasket that has an O-ring setup in the 2nd layer.
Thats all off the top of my head. :)
Not really sure about drift, i'm not really in to that scene to be honest.
I prefer to try and be clean as possible around a track :D
Its good to watch for a laugh though.. When ppl loose it. ;)
The bottom end torque should be good for drift but I would tend to think a motor that is a little more snappy like the rb25 with a decent sized turbo would probably be a little better. Not sure. :rant:
I'm basing that on my rb20t compared to a r33 making similiar power (170rwkw). The R33 was difficult to get sideways out of corners as it was very linear. The RB20t was very snappy and the hard hitting torque transition would cause the tyres to break loose easier.
me got a poor ecuze for a gb :) r33 one....bearing grind :) go for tune up in 14 dayz :) full boozt run :(:D
well I am outta luck for a rb30 block. I have contacted people for one. But they never get back to me. Sydneykid even offered me a built one. But to be honest I can't afford that as of yet. I'll go ahead and take the used block untouched offer.
Anyone?
thanks
Gus
P.S. I have posted every where and still no bites. Anyone please?
Anyone?
thanks
Gus
Hi, I think the problem is you are underestimating how much of pain in the ass it is to send an engine half way around the world. Customs clearance, quarantine inspection, duty declaration, sea freight organisation, packaging and road transport to the wharf etc etc. It's not so bad when you are sending an engine with some value, but is it the same amount of work for a $400 engine as it is for a $6,000 engine. In fact it is even more work because a freshly built engine will pass inspection easily, a dirty, oily, old, used engine is not so easy.
Plus I guarantee you that you will not be able to rebuild an RB30 (to whatever spec) cheaper in the US than what we can downunder. It's false economy, but your choice nonetheless. :cheers:
i hve heard a few diff things and wanna know i hve an rb20 with a stuffed bottom end if i got an rb30et bottom end could i swap everything over and is this a job for a professional
It depends how well you are with your hands and head.
I found the conversion to be a little bit of a pain in the arse (little things like trying to find a 14mm welsh plug & spending half trying to get the gearbox on the back of the motor. It takes sooo much time.. Especially doing it by your self with the odd hand.
Expect the car to be off the road for 1-1.5weeks. I've cleaned everything replaced gearbox, oil water fuel lines/seals. Thats what has taken the time.. Then only to find 'ahh damn i forgot this better order it in from nissan'
I've been taking photo's along the way so I can document exactly what has to be bought or modified to suit the rb30.
Yeah your right again. :chairshot ( you hitting me) lol.
Then is it too late to send moeny for a built block? I still have to sale some other stuff before I can cough up for the rb26 worked head. Please shot me an e-mail at [email protected]
We still have to talk about payment method etc.
thanks
gus
No you need an RB25 or RB26 Head.
The RB20 has smaller bores..
You can use most of your parts, but you need to purchase an RB25DE/DET head.
Not a job you really want to do all on your own, especially the bottom end, new rings and bearings etc.
Please go back over the last 70 pages and have a read..
The beast is alive..
The car idles and rev's as smooth as the RB20DET on the stock RB20DET ECU.
I'm unsure why Darrens R32 had issues, maybe the PowerFC base map is some how very different to the stock ECU map.
I've got a vid & audio clip of the start with only the dump/front pipe on, its not as loud as I expected. Sounds awesome with slight rev's as you can hear the turbo spool. :)
I will post soon.
I will post soon.
Awesome stuff!
I get my PowerFC tomorrow, so i'm not far away from starting mine. ;)
Just a few small things, and running cooler pipes etc. :flamed:
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
