I've had to edit the crap out of the vid as it showed my number plate every where.
So don't mind the chops. :D
This was the initial start *note bits still hanging everywhere*
It was started with only the dump & front pipe on.
The lifter noise has since gone away as they require a few rev's and a bit of running to pump up.
I took her for a little drive. I'm going to have some fun with this RB30..
Acceleration away from the lights in a merging left lane is so so easy where auto's and playing around with the clutch to get off the line without looking like a hoon is no longer a worry.
I've wired the wastegate open as it was making boost all the time, as soon as I would touch the accelerator it would be on boost so it really isn't an option to run 11psi just off idle for the run in.
Its nice to be able to short shift in to the next gear and still power on with no hassles.
Ben, in your S13 its going to be an absolute weapon.
A very enjoyable weapon to drive around.
You could easily have a massive turbo that starts pulling from 4000-4500rpm with the 3ltr as it has so much off boost acceleration it doesn't really matter.
Drive a RB20DET then jump in to a RB25.. Note the difference then multiply that difference by an easy 2 as that is what the RB30 feels like.
It definitely feels like it has heaps more torque down low than my old VS V8 5speed Slugadoor.
EDIT: XVid Codec is required to view the video.
It can be found here - <click click>
It does almost feel like it needs a taller diff ratio though.
See how it goes once the turbo is up and overspeeding.. ;)
Excellent work!!!
Mine is due for collection next thursday, so hopefully i can be joining you in the RB30 goodness soon. I've been 7 months without a car.. so i'm in for a world of learning and grinning :D
Get some footage of the thing driving ;)
The bottom end is due to go into the workshop next week when the rods n pistons arrive. Only had the bottom end for 2 weeks, I want to drive it now! :burnout:
One quick question..
I've noticed since the RB30 it tends to turn over a little slower.
My old man tends to think it could be due to the rb20t starter motor not being designed for the larger motor in turn it draws more amps hence I may need a bigger battery.
Previously the battery was always really zippy in turning over the rb20t..
OR could it be that my earth to the block isn't that good due to paint?!?!?
OR is it just the motors fairly tight still??
I was in the car park yesterday, walked out from the shops went to turn it over and it only just turned over then stopped. I backed off and did it again this time starting.
I remember Darrens R32 RB30DET doing some thing similiar also.
I'm starting to think maybe it is the starter motor not designed for the bigger motor.?!?
It would be interesting to see if the part number varies between the RB20 and RB25 starter motors.
Hi, I think the problem is you are underestimating how much of pain in the ass it is to send an engine half way around the world.  Customs clearance, quarantine inspection, duty declaration, sea freight organisation, packaging and road transport to the wharf etc etc.  It's not so bad when you are sending an engine with some value, but is it the same amount of work for a $400 engine as it is for a $6,000 engine.  In fact it is even more work because a freshly built engine will pass inspection easily, a dirty, oily, old, used engine is not so easy.
Plus I guarantee you that you will not be able to rebuild an RB30 (to whatever spec) cheaper in the US than what we can downunder.  It's false economy, but your choice nonetheless. :mad:
Please get back to me. I wanna enjoy the motor just like everyone else is.
[email protected]
thanks
gus
When using an RB30 you need to be careful what one you use as there is two types, an hitachi and another type, this applies to VL not sure about R31 tho.
The hitachi is rated at 70amps.
Mines been great since using the 550CCA battery...no more startup probs....
yep but what i am saying is where you mount the second tensioner(original idler) the block isnt flat nor is it level with the machined surface that the other tensioner bolts to.
i can work it out myself i just thought you guys had already done it and would know what i needed to do
hrmm.. Not sure..
Its flat?!? other wise the origional idler wouldn't bolt up.
And when you say it isn't the same level... I will have to check that as mine was... :D
I simply bolted up the tensioner on above the waterpump and in the origional idler location and it was all sweet.
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
