It does mark Mark thanx for your input. :)
My pistons are Wiseco also. When cold it sounds much much quieter than the CA18 when warm and can only 'just' be heard to the point where it makes you think is that slap or is it top end noise. Once warm there is zero noise from the motor.
The CA18 when idling after around 3-4hours on the dyno had a rather loud slap that could be easily heard when standing 10meters away. I was actually quite concerned with the noise to be honest.
Phantom, yeah arias usually are not only a lot smaller on the top ring land but also the top land is usually fairly noticeably tapered toward the crown. From memory on an RB arias would be around .035" smaller on the top land and tapered. Where as wisecos are around .020" and parallel. Of all the other pistons ive looked at, JE, CP, Ross, SRP, Venolia, ACL, Speed Pro, etc, they've all stayed much closer to the .008" - .009" per inch of bore with varying from parallel to heavily tapered. Not saying Wiseco dont know what there doing, just that design seems perculiar to them. A good point is it protects the top ring a little more, a bad point is if combustion temps get a little high not a lot of room for expansion before the land will touch....
Top stuff Phantom.
Did the pistons come with a little piece of paper or writing on the box that states the dome cc', compression/pin height etc?
The design at the top and dome height looks ver very similiar to my wiseco's.
What compression ratio are you hoping for?
My RB30DET pistons where $1200-$1300, some where in between.
Both pistons are just as good, it depends on what the engine builder is 'used' to building with.
Mine was comfortable with Wiseco's and said Wiseco's are a good piston, that is what he recommends.
No good building up a motor with pistons you are not familiar with as then you might get the horrid piston slap as per that CA18DET I saw.
The piston slap really was excessive I thought.
Price of the Arias' was around $1320 delivered to your door from Rocket Industries.
The spec sheet does not mention dome volume, but I can measure that. Compression Height is stated as 32.512 mm (1.280"), and the lack of a star stamped under the pin boss indicates that they are 2618 non silicon alloy as opposed to 4032 high silicon alloy.
The compression ratio is not mentioned on the spec sheet however the sales man indicated that they are supposed to achieve around 8.5:1. I'd be happy with that, although I'll see what is in it during mock up.
great post ace_nz full of well thought out facts!!!! I have the new high top Aries specifically made for rb26 heads with rb30 bottoms, will post pics tomorrow, the tappering doesnt look as severe. Yes it is designed to minimise damage to the piston but that doesnt mean its inferior, i have helped put together 6 gtr engines and countless rb30's all with aries and never had any noticable slap noise or any problems whatsoever.I had one failure using weiscos on a gtr the slap noise was noticable from the begining of the bore, the bore was scored and it started blowing smoke, but i am in no way saying this is a regular thing im sure it was a one off, trade price on the arias is $1230, and the Weiscos from memory where $1195 but that was a while ago
also during my mock up the arias sit above the deck height, as do most pistons with this set up but particularly because im using the eagle h-beam rods, however i countered this with a 1.6mm head gasket to achieve an overall CR of 8.35:1.
sorry joel mate that was a typo i meant to say from the start of the run in, i got ahead of myself!
Im running the 4032 in mine but i havent ever really noticed a difference to tell you the truth, you could possibly run a tighter clearence with the other 2618 or whatever? due to lower silicon content but it would be that close i dont think it will matter. all the builds i have been involved we have set the clearence to 0.0035" clearence on every rb series engine.
other engines vary like an sr is run at 0.0045" and ej20 we run alot tighter, due to the closer clearances set by the maunufacturer when they are stock, and you do notice a more audabile knock on start up due to this. you can always hear a knock in wrx's when its cold when its fitted with forgies! i guess this shows you can get a knock from forgies going either way, either with piston slap due to bigger clearences or from going tighter!
Never be scared of a little noise from forgies, you guys should hear what some of the big block chevs sound like with them, massive pistons size with big clearences due to higher afrs to extract power from na's, they are pretty damn loud on start up but they settle in!!
Thanks for the info s13drifter!
The 4032's being the higher silicon content than the 2618 is supposed to be able to run tighter but your right...who knows...without building lots of them and then pulling them down.
Just a few more questions!!.....
I take it you have the chrome rings with your Arias'. What bore hone crosshatch/pattern/machine did you see used with the RB's and what kind of running in did you see done....immediate high load, or gently? Apologies if this is changing the topic.
S13 Drifter , are there any more details on those 26/30 pistons . Is it possible to run the normal head gasket (for high 8's CR) or do valve clearence and quench issues arise . Also what bore size are these and what kind of rings are supplied .
Thanks A .
    • I came here to note that is a zener diode too base on the info there. Based on that, I'd also be suspicious that replacing it, and it's likely to do the same. A lot of use cases will see it used as either voltage protection, or to create a cheap but relatively stable fixed voltage supply. That would mean it has seen more voltage than it should, and has gone into voltage melt down. If there is something else in the circuit dumping out higher than it should voltages, that needs to be found too. It's quite likely they're trying to use the Zener to limit the voltage that is hitting through to the transistor beside it, so what ever goes to the zener is likely a signal, and they're using the transistor in that circuit to amplify it. Especially as it seems they've also got a capacitor across the zener. Looks like there is meant to be something "noisy" to that zener, and what ever it was, had a melt down. Looking at that picture, it also looks like there's some solder joints that really need redoing, and it might be worth having the whole board properly inspected.  Unfortunately, without being able to stick a multimeter on it, and start tracing it all out, I'm pretty much at a loss now to help. I don't even believe I have a climate control board from an R33 around here to pull apart and see if any of the circuit appears similar to give some ideas.
    • Nah - but you won't find anything on dismantling the seats in any such thing anyway.
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
    • You don't have an R34 service manual for the body do you? Have found plenty for the engine and drivetrain but nothing else
