No, I'm running the R32 RB25DE head so that everything simply bolts up and looks stock.
So how'd you get the GTR top feed injectors in,
or are the side feed purely R33
Edited by conan7772
Gotta say,
Before I did this engine rebuild, whilst the car was going great, I always had plans to achieve good hp.
But I first wanted the car to stop well.
Being the R33 GST-t, believe it or not, it actually has the worst brakes than all the other models.
Don't know why this is the case, but it's true.
So Tweakit at Mona Vale fitted an oversized Brembo GTR kit on for me with probably 2mm between the spokes and the calipers, + Green stuff pads.
Having the GTS-t a little lighter than the GTR less more with a light-weight bodykit with these brakes is sensational.
But I still think the ABS is too heavy, meaning the braking could be better.
I wonder if this is programmable or adjustable.
Brakes are fine with a set of good pads on street tyres.
Should I go semi's and hit the track then I may require a set of R33 or R34 brakes to ease pedal effort.
Bushes are well overdue as is a new diff so they are first. :)
Well don't bother with R33 GTS-t brakes.They'll be worse than what you have now.
I picked up a used full set of R33 GTR Brembos for $1700.
Anyway, enough of that, this is an engine thread.
The R33 brakes are fine, they are the same as the R32 brakes but spaced slightly furthur away from the hub as to fit a larger disk under them.
Exactly the same as the gtr 4pots and even R34 brakes.
I suspect you either had extremely dirty brake lines (as i did when I received my car) or you were running crap pads. The R33 brakes are quite good. :)
Bl4ck32 runs the R33 GTST/R32 GTR brakes on the front of his, they area clearly superior and offer better pedal feel than my brakes. Its obvious really.. A larger disk requires less pressure to slow down.
HELLO!!! start a brakes thread...
yeaH gud 1 cubes....lol... um qtn. im sorta half way thru building my 3liter, and am doing some head work. ive had it ported nearly to the water jackets, new valves re seated, and am after some spring/lifter/cam info. any suggestions for some serious revs? solid lifter, wat springs, wat cams???
If you want reliable high rev's do not skimp on the crank oil pump drive collar and aftermarket balancer. The aftermarket balancers are expensive but its the only way an rb30 will hold together. BUT.. that depends on what you consider to be high rpm. Over 7000rpm in my book is high rpm.
Look at any serious high rpm rb26, they also steer away from the std balancer.
Springs will depend on the cams.
i still can't really see any point to using forged pistons in a street car. but each to their own, the extra $600 or so for the build might help you sleep at night anyway, if so it's money well spent i reckon.
we'll see how long my casties last and what power i put down with them reliably anyway, might help some people see the light :(
p.s. had my first run with a fastish car on the weekend - "200rwkw" 180sx down the gold coast. anyway murdered him through 2nd and 3rd - even with the laggiest turbo known to man. i really need a tune too.
Someone correct me if im wrong here but i dont think there is such a thing as a true chromemoly (chromemolybdenum) ring. If there is i imagine it would be HELL expensive. Cause i know in pipe its very very exxy.
My understanding is that there are grey cast iron rings/ductile iron rings and steel rings. However the rings can have certain coatings or heat treatment which improves their base characteristics. Ive heard of rings being coated with chromium or molybdenum to help improve their wear rate, tensile and fatigue strengths. One problem ive heard of with coated rings is they can flake off in extreme conditions. Gas nitriding is one form of heat treatment that is done to steel rings to improve all their stats. I believe that they are the best thats available on a common performance level which most of us are on.
I know acl piston rings have a gas nitrided steel top compression ring. Generally any performance ring set would be good enough for turbocharged engines. But ive heard from numerous people that the best rings are the nissan std ring set which i think would be steel nitrided top ring and prob ductile iron 2nd.
Alot of japanese cars especially turbocharged come std with nitrided steel rings...good to know.
Why not do the job right and use the RB30DET piston from CP?Other RB pistons have the wrong pin height making them a very dodgy option.
interesting post and im quite interested after comparing the 2 pistons on the acl site.
http://www.aclperformance.com.au/NissanRB3...rgedPistons.htm RB30
http://www.aclperformance.com.au/NissanRB2...rgedPistons.htm RB25
in the previous page its mentioned that some height needs to be taken off the rb30 block for the 25 pistons to work. how does that affect compression ratio's in general and how much needs to be taken off. looking at the heights there you would assume .7mm. is that correct?
im trying to keep to acl pistons as im told by the distributor that they are made by ross and i can get them for cost (pistons + rings are around 600bucks). as i want to go for 350kws atw i think its probably a better idea early on considering the cost vs forgies and replacements and the fact my block needs to be bored already.
Edited by SirRacer
The rb30's run a pin height of 1.260.
The wiseco RB25's run a pin height of 1.240. (ACL RB25's run a pin height of 1.233 = 0.027" off the block)
With a lesser pin height the piston sits lower in the bore, so to achieve the same compression ratio as a piston that sits 0.020" higher in the bore you are required to pull 0.020" off the block.
Before you grab pistons dummy assemble it up and take a few measurements to see what pistons with what specs will achieve what ratio.
how do i work this out and is the squench (sorry dont know the exact name) an issue with mixing and matching pistons?
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
    • So, a bit of a side trip, but one that might be interesting for people with JDM cars and japanese head units. I know @Pac previously posted about a carplay/android auto adapter he installed which used the AUX input, and @V35_Paul put in one of the Tesla style units that replace both screens. The option I went with was a Lsait LLT-YF-VER5.87_2 (https://www.alibaba.com/product-detail/Lsailt-8GB-Android-Multimedia-Interface-for_1601187633672.html). Price was $1,150 for a single unit although they are much cheaper if you are willing to buy 2....$857ea. Make you you get the version 2 not version 1, it is faster and has a better UI - this is the manufacturer listing: http://www.lsailt.com/product/348.html. BTW if you've never bought from Alibaba before, don't be concerned....these guys can't stay in business unless they are responsive, ship fast etc, they were excellent (probably faster shipping than most local places) So, this was my task for a lazy Sat afternoon....looks complex but was all done in a few hours (it probably helps that I had some of it apart before so it was a bit familiar). I also decided to add a HD USB drive recorded at the same time and the unit also supports an aftermarket reverse cam (if you don't want to retain factory) and also AV in and HDMI out It looks much worse than it is, in fact in was genuinely all plug and play (no custom wiring at all). This video was pretty good (skipped a few steps), unfortunately they are an Aussie seller but no longer sell this unit (I guess Carplay/AA adapters are easier to install and much cheaper) https://www.youtube.com/watch?v=T5hJfYOB8Dg
    • That still isn't a lot to go on. I don't have a Y50 Fuga Head Unit wiring diagram. I can say that a lot of nissans of that age shared head unit plugs, so if you are in Australia something like this would probably help: https://aerpro.com/app091# You plug that into the car loom, then either plug the head unit ISO into that (if it has ISO), or you buy and ISO adapter harness that you wire in. Bit of stuffing around, but once you have ISO its easy to change things in future.
    • It is a kunfine Android screen . Does anyone know the wirering diagram of the fuga ??
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
