Hey rb30det guys, is it possible to bore out the rb25 block and use rb30 rods and pistons to make an rb30det?
It has been done.
It requires modification of the rb30 crank (destroke), rb25/26 rods and custom pistons.
All though not optimal as the rods would experience greater side load and the piston pin height is bugger all.
But it has been done and appears to work well. I believe the bloke made some where up around 400rwkw and had 8000rpm on board. I'm curious as to how well its holding together some months down the track.
The bloke who did it I believe is mark99. He's in Adelaide.
Hey guys I'm building up a rb30det, I'm ready to start bolting it together just need a head gasket and an oil pump.
What head gasket do you guys recomend, How much and where can i get it? I was looking at a Cometic 1.2 mm metal on this site on a traders forum but now i cant find it again :laugh:
And whats the diferance between the GTR and GTR N1 oil pumps? Is it worth spending a little extra on the N1 pump and why? Also where can i buy one i been told $410 from this site?
What head gasket do you guys recomend, How much and where can i get it? I was looking at a Cometic 1.2 mm metal on this site on a traders forum but now i cant find it again :D
N1 pumps for $410
here - http://www.skylinesaustralia.com/forums/in...howtopic=133537
cometic gaskets
here - http://www.skylinesaustralia.com/forums/in...=131709&hl=
We blew our rb30det :sick: Im pretty confident the n1 oil pump has either rattled apart or the gear has cracked. Will know later in the week when its all pulled down. Its a sad sad day, hopefully its not as bad as it sounds, but she is ceased up completely so im expecting it to be almost totally screwed.
ouch, ouch, ouch... really sorry to hear that. :sick: Plus it makes me nervous...
Very interested to hear if its related to N1 breakage...
I dont know at the moment....Depends on what caused it. But either a brand name one or perhaps a dry sump setup which would be nice. Saturday was the most expensive day of racing weve had so far haha.
How many k's had it done?
I'm fairly nervous with my pump.
No crank collar and its clocked up some where around ~45000km's.
I went the std rb25det pump as I remember at the time my thinking was the N1 pump with its higher relief will place greater pressure on the small crank drive.
Just pure bad luck R33_racer.. :D
Are you running an ATI balancer?
yup...but our car gets thrashed more then a street car would....all day at the track its at or near the max. Yeh we are actually, thats where im lost. I made sure we took almost every precaution available to make sure this wouldnt happen. Collar, everything balanced and ati damper. But we didnt loctite the backing plate bolts in or anything like that, we just bolted it up and left it assuming it was right from factory....so i think thats our mistake unless its a fault with the pump itself.
Im not 100% sure if he does. I think i remember a thread from ages ago where he said he made his own dry sump setup from second hand bits for cheap which they ran on one of the cars. not sure if it was his or another one. Would be interesting if it was on one of the rb30dets. hopefully he will come and explain it to us :D
    • Each to their own I guess  Me, I put just as much time into cleaning inside of the cars as I do on the outside As for getting wet, it is really no different than steam cleaning the carpets at home, apart from the cars carpet dries alot faster than the house, again, I only do it in the hotter months and leave the car opened up for a few hours As I only do it yearly, it is just before I do the diff and gearbox service, so I clean the carpets, then it's up on stands, wheels off, service, clean the undercarriage,  grease the bushings and do a nut and bolt check on everything  Disclaimer: I typically had all the time in the world to kill when I was working 🤣, so spending a full day or 2 cleaning, serving and "looking at stuff" was,  easily achievable, and a fun mental therapy day As for time to kill, I retired last Wednesday, so apart from my physical training, my days are filled with lots of random jobs around the house and garden...."Idle hands are the Devils something something" I am also buying a new house sooner rather than later, I'm actually looking at a potential property tomorrow, I'm looking forward to getting a car hoist as I'm starting to get to old to crawl around under a car, I can only imagine all the undercarriage cleaning and looking at stuff when that gets set up
    • Yeah, I'm not interested in wetting the carpets, and I don't care about brown dirt/dust that lives deep in the pile or underneath. It's not like I crawl around on them in my birthday suit or eat dropped food off them (because there is never any open food in my car). The seats are alcantara (cheap Chinese imitation alcantara, to be sure!) with barely 1" of foam pad behind the surface. That's not getting wet either. Any car that I would be happy to get the interior wet, I would not care to put the effort into.
    • We have one that holds 2.8L of water. On floor carpet that hasn't been touched in 2 or 3 years, will take a minimum of 2 fills of the tank to do a bedroom, and that's going AROUND the bed.   In the cruiser, I used an ENTIRE 2.8L tank, just on the front passenger footwell. But it had some fungus growing, and had been full of mud from being used as a 4WD for many years. I can do that floor again, and it will still pull mud out. However, the water now only looks dirty, not pitch black and leaving full sludge in the bottom of the tank it sucks back into. Oh, and, this is about a $1500 unit.
    • This is mine, works a treat for the cars, suction is good, I use the Bissell clean and protect stuff I have found giving it a good spray and light scrub with the soft brush on the head of the nossle for carpet, and a rub with a microfibre for cloth seats and cloth door trims, prior to another quick spray before vacuuming it up works the best @GTSBoy You would surprised on what it gets out of carpet and seats that actually "look" clean, I recommend that you test drive yours when you have a little time to kill, then post pics of the muddy looking water that I believe you will find
    • I think even the "commercial" capacity ones that you would hire from supermarkets etc wouldn't have the capacity to do all that much in one go. I will go through half a dozen tanks of solution and dumps/rinses of the waste tank for one little 2 seat sofa. Or similar for one 6 footish rug. That's the price you pay for something small that only takes up a bit of cupboard space, instead of something that takes up the entire laundry cupboard or half the shed.
