Ok my compression testing is all done with the Rb26 head on the stock RB30 block.
Came up around 7.5 : 1 which is far to low obviously.
I am going to try and put some RB26 pistons or maybe RB25, and see what that gives me. Anyone that actually knows??
Other wise I have to take 60thou off the head.. which I don't really want to do.
Ben
With the GTR head though you get a CR of around 7.5 : 1,
A 2.5 head will give you the 8.3:1
So I need to know figures using the GTR head, which is quite differen't.
I would love to go and buy a set of forgies.. but now I am pushing close to my budget on this whole project car, and another $2000 or so would throw it over :)
Really need someone who has used the GTR head and has some numbers..
Ben,
Have you thought about using a set of RB25DE pistons, then fiddle with the head gasket to suit the comp you want?!?
I used a Cometic metal head gasket that has several layers.
It also has a O-ring type setup around the bore.
Apparently they use them on a lot of the Group-A's, Nascars & Hi-comp diesels.
Mine set me back $150 from the US.
Basically the same as one of those HKS type headgaskets.
Steve is still running the stocker pistons in his 25t with the CR dropped to around 8.6:1. He's running around 1.3bar (20psi) with no problems YET.
Joel, I actually run around 1.6bar, it has spiked to 1.9bar though.
and what is this YET stuff? everyone seems to think my car will blow up - except the Jap guys that I looked to for guidance, they seem to think it will be no probs. Standard RB bottom end is good for 600bhp according to them, with everything else sorted, and I reckon they should know:p
hehe Sorry Steve.
I'm sure it will be fine. The tuning & CR is sorted thats the main thing.
I had to throw in the YET as I'm a sceptical person. Hell I'm even worried about pushing over 300rwkw on the stock RB30 rods. :)
I've heard of them turning in to banana's at around 380rwkw. But thats only hearsay.
Sounds interesting Joel. Can you tell me more about the head gasket etc??
I am going to take in some GTR pistons and try and find some RB25 pistons to see how these change the CR and see if it helps me. If I get a CR of around 8.3 - 9.0 then I will be happy with it..
Steve you are using a RB25 head correct?
It is really fiddly work with the CR.. I can't just put any head gasket on to fix the CR.. there is only so much you can do.
And as for the forgies costing $2000. By the time I buy them, ship them and install them etc. it adds up.
Seems like no one actually knows what I can do with a GTR head.. will find out soon enough I suppose. :rofl:
well you can buy the pistons locally from many performance places, and you'll have to get the block rehoned and pistons fitted regardless of whether you use stock ones or forgies.
But from the 3 posts you've made i understand you don't want to go down the forged pistons road so i'll stop harping on the subject... just though i'd bring up that as an option.
Hi GTR Ben, I have read the last few pages of this thread a couple of times and they make no sense. It must be me, maybe a few facts might help;
There is no difference in the combustion chamber size between an RB26 head and an RB25 head. They are both between 62 cc's and 64 cc's depending on casting differences.
RB30E and RB30ET (SOHC 2 valve cylinder) heads have around 56 cc's to 58 cc's combustion chambers.
If you use RB30E pistons with an RB25/26 head you end up at 8.3 to 1. This was posted a number of times in the 42 pages. If you use RB30ET pistons you end up at 7.5 to 1, this was also posted.
RB25/26 pistons have the gudgeon pins located around 2 mm lower than RB30 pistons. So if you use RB25DET or RB26DETT pistons in an RB30 with standard RB30 conrods, you end up with the pistons 2 mm further down the bore than RB30 pistons.
The answer is to take 1 mm off the block and 1 mm off the head and if you use RB25DET pistons you end up at 8.3 to 1. Same as if you used RB30E pistons. But the RB25 pistons certainly look tougher, so I would prefer to use them.
All of these dimensions are approximate, every engine is unique and you should do precise actual measurements of you own personal components.
Bottom line, I personally would not recommend taking 2 mm off the head alone, you would end up with too little metal at the water jacket to head gasket face. Plus it would remove too much squish zone which is a very effective feature of all RB DOHC, 4 valve cylinder heads.
Hope that clarifies.
Thanks for the info.. I don't really know what is going on but I have had numerous engine rebuilt and work done from this shop and I am 100% they know what they are doing..
Unless my GTR head is aftermarket?? as it is ported and had aftermarket valve guides etc, and the head is definetly 67cc's.. you can see a larger lip between the contact point with the block and the part where the valve seat.. about 2mm more than a RB25DE head??
These guys have gone over all the squish zones etc with me, (which I don't 100% understand) and they have set the engine up to be good in all these areas..
I understand you know what you are talking about Sydneykid... and I was sure that the RB26 head had about 63cc..
Only conclusion is that it is an aftermarket head..
It has already had the head shaved and setup. Compression ratio is now 8.45 : 1 with a stock RB30E gasket.
I think it was slightly more than 7.5 : 1 to start with as I didn't give them a gasket and they just estimated the amount.
Well it's all done now.. just have to put it back togethor. Got my GT3040 turbo and 42mm Turbonetics wastegate on its way.
And the Silvia is almost ready to drop it all in.
Thanks for all your help guys, wait for photos and vids :)
Hi GTR-Ben, in an R25/26 cylinder head there is plenty of metal to increase the size of the combustion chamber. This is actually technically a better solution than using a thick headgasket. You may find that your head has been worked on to lower the compression ratio of the previous engine it was fitted to.
By going to 67 cc's for the combustion chamber, this would lower a standard 2.6 litre RB26 to 8.2 to 1. Or it would give a 2.7 litre an 8.5 to compression ratio. These are all common numbers for medium tune from Jap workshops.
I have 4 X RB26 cylinder heads in the flow bench room right now and the largest is 64.4 cc's. We have probably done 20 or so to date and none are over 65 cc's standard.
Hope that clarifies further
ive just finished putting on a rb25de n/a head on an rb30e block .
i used the rb25de n/a pistons on the rb30e conrods
pistons sat approx 1 mm lower in the bore
rb25de n/a pistons have a much larger dome than the rb30e pistons .
by my calculations ( no not guessing ) the compression works out at 10.5 - 1
The bloke who built up mine & Darrens RB30 said after he's finished the 400chev sprintex supercharged motor he's building, he's going to have a go at a RB30DE(S) using a sprintex supercharger. He's asked around and researched in to it a bit but no one is really telling him of any results. He's dropping the motor in to a Commodore, VL I assume.
If he goes through with it i'll post up results and how he goes with it. Should be rather interesting. I also assume it will be up around the 400-500hp mark as that is what his current 400chev ute is making.
Whoohoo, Get to pick up the motor up tomorrow.
Its all bubble wrapped strapped on a pallet. Problem is I havn't got a fork to pull it off with. :( I can see my self stressing out tomorrow.
I can't remember if I posted or not. I ended up using a Series I RB25DET oil pump, Andrew checked the clearances etc. & lots of lock tight on the bolts. :)
Its been a long 44 page & 10 month journey since I was asking if the RB25 & rb30 pistons were the same dia. :D
:D :headspin: :D :headspin: :D
Just to scare a few of you off. :)
I did the sums of how much it has cost me.
All up it came to around $6500-$6600.
Thats including extra's like head reco port/polish, head purchase, clutch, getting the head fitted, cam belt, oil pump, waterpump, flywheel, harmonic balancer etc.
Now add the turbo, injectors & ecu on top of that. Then the gearbox will die then my diff will definately be open wheeling.. lol
Oh well another 2 years of Uni left to throw money at it.
EDIT: I forgot the VRS kit.. thats an extra $275. Make it $6775-$6875. ouch.
Gary, I remember you saying a long long time ago. Performance isn't cheap. :D
Would have wasted that money through out the year anyway, at least its gone to something. Thats the way I look at it.
It would have worked out basically the same for me to build up a R32 RB25DE engine.
If you are re-building an engine it is always going to cost around the 5k mark for some thing decent with forgy's etc.
My origional plan was to freshen up a RB30 bottom end (1100) then slap the $750 RB25DE head straight on top. Then I had the idea.. ahh I'll spend another 1k on the head to reco port/polish it etc. Then I had another idea.. ahh I'll spend another $1300 or so on forgy's... and another I really should get it all crack tested, blueprinted and well yer.. :)
HiGuys, I don't think DOHC, 4 valve engines go together very well with superchargers. They have such a wide RPM band that it is very difficult to match the supercharger sizing. You either end up with a torque monster, with nothing over 5,500 rpm. Or a down low unresponsive slug, that leaps into action for 1,500 rpm or so at the very top of the rpm range.
Being positive displacement and permanently running at crankshaft rpm X gearing, they make sizing a turbo charger seem like child’s play. Fantastic on a big block Chevy (we have a 1,500 bhp one) but anything over 6,000 rpm is flat line time.
I won't be putting one on my RB engine anytime soon.
Gary,
How do the R32RB25DE cams work with cam gears?
Does it help peak power to be made higher in the rpm range?
ok I'll reword it.. Would u use a set of Adj. cam gears on a RB25DE RB30DET which will be running a HKS3037 to crack the 300rwkw?
Gary,
I've done a bit of research and calculations in to this Squish Band.
Well ... Sh*t.
If only I knew what I know now when I selected pistons/comp ratios.
(Piston sitting 2.5mm down the bore with a 1.14mm (.045") head gasket, 14cc dome & 62.2cc Head = 8.2:1)
That’s providing my calcs are correct which I am now starting to have a pretty good understanding of all the calcs. I am 100% sure its right.
The apparent perfect squish band tolerance is .76mm (.030") – 1.52mm (.060") (deck height + head gasket thickness). It isn't that simple though.
You also should check the maximum squish velocity (MVS) to ensure it isn't extreme (its not linear either) and well there is more but it is damn complicated.
I think sticking to the Nissan .053" (my calcs can any 1 check for sure?) squish spec should be about right as they have obviously done the calcs with regards to the size of the squish band.
So yer as you said previously.
Flat top pistons with a nice deck height and head gasket to suit is best.
Basically exactly the same as the way it rolled out from the factory.
BUT.. :D
These apparent negatives.
I've searched hi and low but haven’t actually found any hard proof how much it actually does affect an engine, its mainly hearsay.
Economy? Emissions? Performance? Response?
Have two exact same spec RB30DET's, same boost comp ratio etc would it be noticible by the seat of the pants feel? One 3.5mm Squish one 1.35mm squish. hehe Sorry for the flicking between imperial/metric. :D
Surely some one has done a test in the US of A with their Hemi's.
One thing good that has came out of all this is I am feeling content that I have learnt a lot. ;)
    • Thanks for the reply mate. Well I really hope its a hose then not engine out job
    • But.... the reason I want to run a 60 weight is so at 125C it has the same viscosity as a 40 weight at 100C. That's the whole reason. If the viscosity changes that much to drop oil pressure from 73psi to 36psi then that's another reason I should be running an oil that mimics the 40 weight at 100C. I have datalogs from the dyno with the oil pressure hitting 73psi at full throttle/high RPM. At the dyno the oil temp was around 100-105C. The pump has a 70psi internal relief spring. It will never go/can't go above 70psi. The GM recommendation of 6psi per 1000rpm is well under that... The oil sensor for logging in LS's is at the valley plate at the back of  the block/rear of where the heads are near the firewall. It's also where the knock sensors are which are notable for 'false knock'. I'm hoping I just didn't have enough oil up top causing some chatter instead of rods being sad (big hopium/copium I know) LS's definitely heat up the oil more than RB's do, the stock vettes for example will hit 300F(150C) in a lap or two and happily track for years and years. This is the same oil cooler that I had when I was in RB land, being the Setrab 25 row oil cooler HEL thing. I did think about putting a fan in there to pull air out more, though I don't know if that will actually help in huge load situations with lots of speed. I think when I had the auto cooler. The leak is where the block runs to the oil cooler lines, the OEM/Dash oil pressure sender is connected at that junction and is what broke. I'm actually quite curious to see how much oil in total capacity is actually left in the engine. As it currently stands I'm waiting on that bush to adapt the sender to it. The sump is still full (?) of oil and the lines and accusump have been drained, but the filter and block are off. I suspect there's maybe less than 1/2 the total capacity there should be in there. I have noticed in the past that topping up oil has improved oil pressure, as reported by the dash sensor. This is all extremely sketchy hence wanting to get it sorted out lol.
    • I neglected to respond to this previously. Get it up to 100 psi, and then you'll be OK.
    • I agree with everything else, except (and I'm rethinking this as it wasn't setup how my brain first though) if the sensor is at the end of a hose which is how it has been recommended to isolate it from vibrations, then if that line had a small hole in, I could foresee potentially (not a fluid dynamic specialist) the ability for it to see a lower pressure at the sensor. But thinking through, said sensor was in the actual block, HOWEVER it was also the sensor itself that broke, so oil pressure may not have been fully reaching the sensor still. So I'm still in my same theory.   However, I 100% would be saying COOL THE OIL DOWN if it's at 125c. That would be an epic concern of mine.   Im now thinking as you did Brad that the knock detection is likely due to the bearings giving a bit more noise as pressure dropped away. Kinkstah, drop your oil, and get a sample of it (as you're draining it) and send it off for analysis.
    • I myself AM TOTALLY UNPREPARED TO BELIEVE that the load is higher on the track than on the dyno. If it is not happening on the dyno, I cannot see it happening on the track. The difference you are seeing is because it is hot on the track, and I am pretty sure your tuner is not belting the crap out of it on teh dyno when it starts to get hot. The only way that being hot on the track can lead to real ping, that I can think of, is if you are getting more oil (from mist in the inlet tract, or going up past the oil control rings) reducing the effective octane rating of the fuel and causing ping that way. Yeah, nah. Look at this graph which I will helpfully show you zoomed back in. As an engineer, I look at the difference in viscocity at (in your case, 125°C) and say "they're all the same number". Even though those lines are not completely collapsed down onto each other, the oil grades you are talking about (40, 50 and 60) are teh top three lines (150, 220 and 320) and as far as I am concerned, there is not enough difference between them at that temperature to be meaningful. The viscosity of 60 at 125°C is teh same as 40 at 100°C. You should not operate it under high load at high temperature. That is purely because the only way they can achieve their emissions numbers is with thin-arse oil in it, so they have to tell you to put thin oil in it for the street. They know that no-one can drive the car & engine hard enough on the street to reach the operating regime that demands the actual correct oil that the engine needs on the track. And so they tell you to put that oil in for the track. Find a way to get more air into it, or, more likely, out of it. Or add a water spray for when it's hot. Or something.   As to the leak --- a small leak that cannot cause near catastrophic volume loss in a few seconds cannot cause a low pressure condition in the engine. If the leak is large enough to drop oil pressure, then you will only get one or two shots at it before the sump is drained.
