Answers after each question....
I have a few questions you guys might be able to answer.
1. when will boost come on when using a Gt3040 (475 hp)  with 9:1 comp, power fc with boost controller.
- Around the 3300rpm mark
2. For the guys with over 300rwkw, did you use the standard rb25 sump?, are these baffled?. -I know they have crank scrapers which need to be removed with the rb30.
- i'll be using the standard RB25 sump, i haven't been told any different or read they can't be used
3. another one for the 300rwkw club.  Are their any problems with the standard manifold?.
Ive heard that air is not distrubuted evenly into all cylinders, people have made some mods to the inside of the manifld to fix this problem.
- the standard inlet manifold is fine. It flows suprisingly well
4. Are aftermarket manifolds worth it?.
- depends what you are trying to achieve, if you want big power (450kw+) then yes they may be a benefit
5.Will the rb26 manifold complete with throttle bodies fit onto the 25 head?.
- not without expensive mods. I think there was someone selling adapter plates or something, can't remember
6. attached is a pic of a modified rb25 manifold.
What do you think of this?.
- I wouldn't do that. The inlet plenum is designed to have the air fed from the stock place. Nissan's engineers are pretty smart! If you want a front facing plenum then get one either off the shelf like a Greddy plenum or one made from someone that has designed it to work correctly like Sub Zero rather than just cut and shut the stock one.
Im using the rb20 sump. The engine builder just bent the fins back to clear the rb30 sump.
If u want good power over 300rwkw, go for a tubular exhaust manifold, and ext. gate
Intake, if u need it, can be bought from RIPS. Give him a pm, he makes a front facing jobbie in kit form (plenum, accelerator cable, throttle body). They must be good if he's in the 10's with his rb30det's :)
What depth etc do I drill the new tensioner hole to on the block?? A more exact location.
I don't want to hit a water gallery or drill into my bore :)
Oh and what do you guys do about mounting the powersteering etc, as the RB20 etc brackets wont fit the RB30. Do you use the RB30 mount?..which i don't have. And what about belts?
Thanks Guys,
Ben
With regards to mounting the powersteering.
I've just had a look at the two blocks.
The RB30 block is obviously taller. Hence the powersteering bracket cannot bolt in to the provision available at the front of the head. However in that same location (just above the waterpump) there is a hole available in the block where the hole normally would be in the head without the extra deck height.
I've posted a couple of pics.
It all looks the same to me from the pics. I hope it is. :)
To the guys using an R33 head (VCT), what injectors are you using? i've read 13B series 6 (550cc) injectors fit, but not sure if mods are needed. S15 SR20 has 440cc, and being nissan should drop straight in?? 7MGTE, 2JZGTE, 1JZGTE are all 430cc, but again unsure if they will fit.
Anyone had experience with these setups? If possible, i don't want to stuff around making a new top feed rail.
Impedance shouldn't be an issue, as i will being going aftermarket ECU. A resistor block can be made easily anyway if need be.
R33 fuel rail/inlet manifold are setup to use side feed.
R32 fuel rail/inlet manifold are setup to use top feed.
I was under the impression that the 13B 550cc injectors are top feed as Bl4ck32 has recently got his self a set.
So Unless the 13b injectors are sidefeed you will have to mod the R33's fuel rail.
Have you actually tried to bolt it on though?
It won't actually bolt on, but with some mods it should. Grind it a little.. :rofl:
I used the rb30 powerstearing pump bracket - bolts straight on and no problems to hook everything up.. Mine cost me $20 from the local commo wreckers.
about the compression ratio.. honestly when you get going I don't think you will eaven notice the difference. Off boost the car is still more than able to pull your house down. I personaly think you are wasting cash that could be spent elsewhere.
Just a question that I have for you all. What Oil should I be running in my motor?
Atm im running Castrol GTX3 (up to done 1200k'z) Is this oil ok for the motor?
I did the first 500km'z on GTX standard.
Yeah Joel, looks like you will need the RB30 one.. it's the shape of the bracket that stops it from working with the RB20 ones etc.
A lot of people use the RX7 550's. They seem to give pretty good results. I just bought some myself.
Some people told me the spray pattern is no good.. but if they do the job then..
    • Hey all  im wondering if you can help me please I have put a rb20 box in my r34 gtt as my auto packed up and a friend had a spare box I know it’s not ideal but it will get me up and running for now. we have done the conversation and everything is working great but my Speedo we got a s13 speed sensor but my Speedo reads double now and I bought a speed converter but still not having any luck.  so I thought I’ll reach out and pick your brains  any help would be appreciated please as I wanna drive my car again
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
