My crank has been balanced and all the rest of it, and it regularly see's 7500rpm.
I know of one running to 9000rpm running a factory (abeit modified) crank.
Anything past 7-7500 and I think you'd need to look at aftermarket rods.
Cheers,
matt
hey guys,
anyone looked into the safe RPM limit of an RB30?
I have spoken to someone who said that anywhere over 6600rpm is asking for trouble. I was looking at using a 7000rpm limit, but was told i would be treading lightly on reliability.
any info?
what about a viscous-filled harmonic balancer?
i had/have the option to go for eagle rods, but i have been told they are heavier than standard, altho stronger.
prepped arb30 rods would be easier to source in the event of a breakage too i would imagine... and more cost effective
if you have rods, and pistons all balanced with the crank and flywheel/clutch then you should be able to take it past 7500 no problem. But the power levels will be big well before 7500rpm so you don't really need to take it past that. An Rb25 harmonic balancer is also a good idea, but as sydneykid will tell you, he uses new RB30 ones with no problems!
Andrew
Re: visous balancer - not too sure.
If you can afford it, I'd go the aftermarket rods just for that extra piece of mind.
If you really want to rev hard, spend the $$ and get the crank balanced too.
Can I ask why you're concerned with reving to 7500rpm?
My motor makes peak power around 5800-6000rpm and thats with bigger cams and a turbo that'll flow roughly 700hp. They don't need to rev as hard as a 26 to make power.
Cheers,
matt
All motors have inherant harmonic issues, so you can't single out the RB30. You'll notice that anyone building up a "decent" modified V8 has plenty of aftermarket harmonic balancers to choose from, and this part is generally always changed.
Unfortunatley, the options from Japan for the RBxx series are the ATI/HKS fluid damper ($1200), the Greddy billet alluminium hub (no balancer, ~$600) or a Route 66 rubber damper ($1000). The ATI item is the best available, buying it through HKS also gives you the pulleys, if you go direct to ATI you can get it a hell of alot cheaper but no pulleys (go go Gadget fabrication) and there are 8 or to choose from with alloy or steel shells.
Having said that, there are plenty of RBxx motors using a standard one without any dramas. However, at high RPMs I think that the harmonic balancer contributes to oil pump failure and also crank damage - I've seen a few RB26 cranks with the keyway split or the hub for the oilpump damaged.
So I guess you can add this part for a no-holds-barred, no beg-your-pardon's type motor. But it's not a necessity.
i just wanted to make sure i could take it to 7000rpm limit and not be shattering any oil pumps :( I would like to go forged rods but have heard melancholy stories about eagle rods and cannot afford 2k for carillio/argo's.
On an RB30 i would consider anything over 8000rpm as high revs. From the reading i've done, anything under that i fine. An RB26 i would consider over 9000rpm as high revs.
RB25 balancer will go on the RB30. All RB balancers do (i've been told by people i believe). I will know for certain in a week or so :(
Andrew
All inline 6 cylinder engines are internally balanced, therefore the clutch and harmonic balancer do not have to "carry over" any external weighting and are neutrally balanced.
Looking at an RB26 vs an RB30 balancer there is not much external difference, but given the fact that the RB26/25 are a later model motor I would assume that they are both a) made from better materials and processes and B) there is less chance of the rubber cushioning material to be damaged since it should be a lower mileage motor.
It all comes down to the fact, how much horsepower can you afford to make?
edit: all the RB series are interchangable, from harmonic balancers to flywheels/clutches.
From every one I've spoke to who have built high reving RB30's and making over 700hp they all tend to change (or stiffen up) the bottom end by using an aftermarket cradle & different re-inforced sump.
Apparently by stiffening up the bottom end it shifts the harmonic issues higher in the rpm range that will never be touched.
Not once was it mentioned people playing around with harmonic balancers.
Oh - I forgot to mention - the RB30 I mentioned earlier which rev's to 9000rpm (and makes 800-850hp) was a GTR - so the bottom end is stiffer because of the front diff. The torque is what warps the blocks though - not the revs. Although I haven't heard of any twin cam RB30's doing that.
On another note - what are people doing with the head studs? I'm still using factory ones - but has anyone gone bigger?
Cheers,
matt
The RB25 and RB30 harmonic balancers, whilst being physically interchangeable appear to have a different construction as already mentioned. However the point of interest is that they also have consequently different states of harmonic tune as they have differing effective weighting on the damper section. Speculating, one would assume it is to compensate for the different harmonic characteristics of the different cranks i.e. the RB30 is a longer stroke than the RB25. I have long wondered about the harmonic issue talked about at 7500 RPM, but it seems no one has ever done a proper test to see what exactly is going on. Is it a TORSIONAL harmonic issue? Is it a BENDING moment issue? Anyone ever had a close look at the damper used on the Autospeed monster RB30 by Nispro? That looks like it has substantially more mass to it on the damper ring.
For my long serving RB25/30 I used the RB30 balancer with no apparent long term effects, and a strictly enforced 7000 RPM limit. Without testing though I can't say wether or not it was the right decision.
The "AFM = restriction" is a myth, you just have to have the right sized one for your application.  Spread the word.
not so much the afm , but the rest of the inlet piping may cause a very high restriction , as seen on the test on the vl turbos inlet on autospeed.
but i agree with u , correct size of afm for ur application and it wont hinder anything.
Cheers,
matt
why does everyone rave on about head studs , why not use the original stretch bolts , but use a torque to yeild ratio when tourqing them down. instead of just bolting it down to the specs in a work book.
sydneykid - do u agree with me or do u see no need for it?
and as for rod bolts , im still not sure if arp make ones to suit an rb30 rod , though a simple way around it is using sr20 bolts , just need to buy 2 sets (as there is four pairs in one set , 4 cyl's of course)
I was curious more than anything else... As I mentioned - my car still uses factory ones.
Re: rod bolts - not too sure about ARP bolts, but I've got Tomei rod bolts which are around about the same price.
Cheers,
matt
    • Am I correct in assuming that the R35's are getting the classic skyline haircut off the odometer?  Quick search on carsales, there are 33 08 and 09 GTR's for sale, only 2 of them have more then 100,000km's on them (116,075 and 110,000 respectively).  And somehow there are about 25 for sale with around 60,000kms? Looks like the classic skyline haircut to me =/
    • @Stringycheese  Have you only gone to the one blue slip workshop?  There will be a heap of them where ever you live, good odds that the next place you go to will pass the car.  Unfortunately (or fortunately?) every blue slip / engineering workshop will be different and will be happy passing or failing different things - despite working from the same set of rules. It's kinda like 2 lawyers arguing over a piece of legislation, each saying their interpretation is correct. Might seem strange that this happens when it comes to getting a modified car passed, but this is very much a thing. A big part of the game is finding an engineer / workshop that is on the same page as you.
    • Bah. I daily mine. ~60km per work day, 10-12 thousand km per year. What's the point of having a dirty old Datto and leaving it in the shed. It needs to be driven and enjoyed while the govco allows us to do so. It will only be a few years before we're forbidden to even start up internal combustion engines.
    • Judging by that spring perch and the normal looking spring on it - not a coilover. Well.... it is a coilover, just a stock format coilover, rather than what everyone calls a coilover.
    • Yes it is. We get stock from Nismo directly. I'm happy to take photos/video of it as proof before I ship it with timestamps or whathaveyou.
