Just readin through. im puttin an RB30dett in my 32gtst, am i gana have any problems closing the bonnet with the 26 head on it? got a GTR bonnet 2
As long as you use the RB26 inlet system, no problems. :D
One other question...what is the size of the std RB20 throttle body...is that what you guys with teh RB25DE heads will be running? Not concerned about combination of 600hp turbos on RB20/25DE manifolds and RB20 throttle body?
Just trying to suss out the weakest link in the setup that im looking at for my car.
im using everyting from the rb20 for the run in...er...excext the r33 box, twin plate, cam gears and high flow rb20 turbs to strart.
When the bigger turbo goes on, new front facing manifold will go on (RIPS:)) with an enlarged rb25 throttle body, or the Q45 jobbie :D
the port shape is larger on the bottom half of the 25DE than the rb20 bottom half. The top half (rb20) i used because the AAC valve is different from rb20 to 25de....
But the two hacles bolt up evenly together? So its just the inlet port shape on the RB25DE head doesnt match up 100% with the RB20DET manifold?!?!?!
Is it close enough that soem match porting/shaping will fix, becuase i was goin to get that done anyway (extrude honed as well)
Thanks for the help ppl
I have a RIPS intake, the whole motor is still wrapped up so I cant comment on performance yet.
Those of you using an RB25DE head, do any of you plan to use a power fc? If so, what model because as far as i can tell, there are none for the RB25DE?
I imagine there would be differences between the DE and DET making the RB25DET unit unsuitable but I am not sure and have no proof to support this.
Thanks
ok...the top rb20 and bottom halve are the same (can do minor port work), its the shape of the ports to the head is whats different...i'll get ya a photo...
the first is the rb25de runners + rb25de gasket. Ports on the rb25de head are roughly the same size as the gasket. Next is the rb25de gasket on the rb20 runners...notice the difference?
Whatever car you are installing the engine into dictates the sensors you will be using, as well as the version of the power fc. Ie R32 = AP Engineering, r33 std r33 unit...
Champion...thankyou. Fair enought they are different, but as im having trouble finding a cheap RB25DE inlet manifold then it may be worthwhile matching the RB20 inlet manifold.
Thanks again....the only other question is has anyone matched up the exhasut side of the ports. Trust list the same aprt number for their RB20DET and RB25DET manifolds, so was going to stick with what i got. Onyl it is already ceramic coated, and may just sell the thing off it i really need to be match poerting the exhaust manifold to the exhaust ports
As far as i know all rb20 /25 ehxaust manifolds are the same....due to the size not being too big or small having to do with the optimal size to spool the turbo...they are all the same. Im using the rb20det exhaust manifold. No difference in port size when i looked to the rb25de head....
I've done a bit of looking in to the stocker exhaust ports.
The lumps in the ports are designed with the manifold in mind.
If you are using the stock exhaust manifold leave the lumps in the ports, if not then remove the lumps.
The lumps help direct the exhaust gas in to the stocker manifold.
Took my RB30DET in today to check fuel ratios before running it in. After playing around a bit, getting it to idle good and setting the wolf to run a little rich, it made 160 rwhp at 3800rpm rev limiter and was producing a little over 1600 ft lb of torque with a very step horsepower curve. Are these figures close to what over ppl have in there rb30's??
Sorry R32. It doesn't make sense what you said..
So you set your rev limit to 3800rpm?!?!
Thats 119rwkw. Fairly low but for 3800rp I suppose its ok for a stock turbo running stock boost.
So peak power was at 3800rpm?!?!?
Nar will find out what peak power is after i run it in. So i set a rev limit of 3800rpm so i cant get tempted to run it hard when its not run in properly. So at 3800rpm it made 160rwhp and its running fairly rich and with no timing, and stock boost, with a stock RB20 turbo hi-flowed
I asked this question a while back but no one has replied. I have a wolf 3d v4 in a R32 skyline with a RB30DET. Now i want to be able to control my boost with a boost solenoid, which will be controlled with the wolf. However the R32 didn't come with them. Anyway i was abvle to get a solenoid but are unsure of how to connect it up.
This is what i think i have to do:
1. Take out Duel Stage boost controller and connect hose to solenoid instead boost controller.
2. Pretty sure its the bottom nipple, the top nipple leave along.
3. Hook up the 2 wires that are connected to solenoid the the wiring harness.
4. But which wires does the solenoid have to be connected to so that the wolf will be able to control the boost.
Can someone help me??
    • A 1.5 way is a 2 way. It is just a 2 way with a less aggressive ramp on overrun.
    • The ABS and/or TCS being missing/broken will not cause the engine to misbehave. It just casues CEL to come on and annoy you. The CEL is useless if it is always on, so you have to do the things you have to do to get rid of it, so it can be useful. Being a Stag ECU, then yes, it will not expect TCS to be present. But it will expect ABS to be present and working. You will need to either make the ABS CU talk to the ECU (don't ask me what that will take on an NA R34), and make sure the hardware is working....or, you just need to blank it out in Nistune. Do not persist with the stock ECU. You will just have problems. Gte it Nistuned. Start from there. DO YOU HAVE A BOOST SENSOR? The ECU's boost sensor that it. It is connected to the loom at the rear of the coil cover. Usually rides on the firewall on an R34, but is usually bolted down to a bracket along with all the other crap at the back of the coil cover when a Neo is dropped into another car. If you do not have it, the ECU will shit the bed. So, do you have one?
    • So sadly the fuel pump etc was not it. The pump and filter is new and it is still cutting around 4000 rpm. A read something about ABS/TCS (engine is from stagea and ECU too so no TCS) and i dont know for 100% that my car has ABS. It has ABS "cube" in engine bay but i dont think it works(or at least from my braking experience). Can be something like that?  I will be driving the car next week to Nistune tuner to properly see what is wrong...
    • the Tomei LSD fluid with lsd kit. frustrated that it was shaking the car to crap and affecting everything else negatively, I pulled the diff last night, and removed the lsd carrier, could not find anything wrong, however it seem to be 100 locked up acceleration, and deacceleration, wondering if they sent me a 2 way not a 1.5??  either way I installed the stock open carrier back in place. test drove everything smooth as butter again. no shake, shutter, random, what felt like clutch slip and grab or drive shaft play, etc. something differently wrong in side the lsd. I might bother taking it apart (if possible) to figure out what's going on inside this carrier, as bought too long ago to return.  only draw back is its back to a one wheel wonder.
