hey guys,
basically i need a drift wing... but i am going to modify it myself and install an led brake light.
can anyone tell me where to get one besides carmate or are they all the same fit?
if ppl say carmate is shi* with bodykits etc. then surely theyre d wings must be a bit flimsy
give your input! i wanna go buy one today lol
cheers
https://www.sau.com.au/forums/topic/154332-d-style-wings-buy-from-carmate-no/
Another vote for no re:Carmate.
Buy somewhere local where you can see what you're buying 1st hand.
I'll never again buy a fibreglass/carbon fibre/aftermarket bodykit without seeing it in person..I've learnt my lesson..
I'm not gonna say anything bad about car mate.
There is this place that I coulda sworn sounded very similar to car mate that I wouldn't ever go to though. hmmm... I wonder what the name is.
The people at that place are arrogant pricks, have shit quality parts, shit service if you try and bring stuff back.
If you have a problem, you will not get a refund. Simple as that.
Even me wanting to swap for something else in the store, took about 5 hours of telling the prick off
The guys at said place also stink like asian fish.
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
