Well I got it last night after work.
First impressions are it's incredible.
It's beatiful to look at up close. The fit and finish is very good for a suzuki.
Not quite Yamaha, or Honda quality but they are getting there.
The stock exhaust sounds awesome! The best stocky i've ever heard, and it looks horn just like a motogp style exhaust.
The engine is still very tight i'm not supposed to go over 6000 revs to begin with. I went up to 7000 last night and wanted to keep going but i need to bed all the parts in before i start going balistic.
Damn it's a good bike.
So anyone that wants someone to go riding with just let me know.
But i'll still be coming to SAU south australian events.
Dad also got a new bike yesterday.
A new Yamaha FZ1.
It's an R1 engine from 2006 in a more upright semi naked bike.
The engine is tuned a little differently and has much more mid range than an R1.
It's pretty damn nice though, i went for a quick ride last night.
Thanks for the offer, but i love the flickabilitly of the 750 plus it has more than enough power for my skill level.
Makes me laugh when people equate cc of a bike to rider level skill. If your a noob on a 250, your a noob on a 1000cc.
Rider training is worth its weight in skin....gold...i meant gold :happy:
Not having a go at all...
I just dont agree with people who seem to think cc of a bike should = skill level. Look at the learners who are too physically big to ride 250cc for a first bike *Looks at Tangles* :kiss: (what was your first bike there?)
A 1000cc bike is no different to a smaller cc bike...except 2 things. Weight and revs...
Someone who isnt accustomed to riding (not yourself) would more likely get on a 600cc bike say, and ring the nuts off it thinking it wont be bad, because its only a mid size bike :happy:
Wish i had a dollar for all the noobs ive heard of getting on a mid size cc bike and doing 160 on the street in the flick of a wrist...yet they wouldnt jump on an R1 say and attempt the same, just cause its a 1000cc....
Well i have no problem jumping on any bike a ringing the neck off of it.
Like i said, the 600's lack torque down low, and i love the how well the 750 turns.
Like most magazines have said, it has almost the power of a litre bike and handles as well a 600. So that too me is a perfect bike.
Zx-14 is good for one thing... country miles.
The new ZX-6R just came in and looks great. I might have a test ride on it this weekend.
Bl4cK32 in regards to your earlier comment having a smaller bike i beleive does boost your confidents. On the 600's i've cracked the throatle coming out of corners and it's just powered out. Where as when i tried the same thing on a zx-10r on the same corner, it started to do a massive drift. And that affects ones confidence. It meant when riding i was more timid about opening the throttle right up.
This was about 3 years ago though.
Yer i agree with learning on smaller cc bikes, no arguments.
Its always good to progress to larger bikes. In fact SA should follow the other states with 250cc restrictions (2stroke racers - which i learnt on (and still own :D) then have another licence for say 600cc then above...
All should come with proper rider training, not the "sit on the bike with it turned off, and let someone push u across the range" that they do currently...
Well had my first hills ride and proper ride on the bike on Saturday.
And hell it was good fun.
I didn't feather my tires right to the edge, and my lines were all over the place. But it felt great to get back out there.
Now just need to get back into rythem.
  • 1 month later...
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
