a bit lower i'd say - standard stuff - spring rates would be softer and s13 strut length a bit shorter
as for coilovers - hard to say - as they all vary in height anyway. I run S13 ISC in my car at the moment and they're PHAT. i havent got a problem with it being too low, but ISC now offer a different design with the strut bottoms so that it can be a little higher.
:laugh:
Huddy: I thought that the new bottom bracket was to lower the car more? I remember seeing a lot of threads on NS about people not being able to get their cars low enough.
I would think that the spring rates would be pretty similar. Ride just seems more comfortable because the body is heavier.
My 2c anyway
You got to be careful though...
I purchased s13 Tein coilovers, they were in my car for about a week before I ripped them out.
Its highest settings was still too low. It had NO suspension travel on the front and very little in the rear. (Car just didnt become a pleasure to drive). I was bouncing everywhere couldnt hold the accelerator pedal in the right spot as any little bump would move the car up and down but my foot would stay in the same spot, and I was accelerating more for that half a second (if that makes sence)
Slowing down for corners was the worst, any little bump on the road and the front tyres would lock up for half a second as it got so light over the front tyres, sometimes airborne over small bumps.
So yeah, ive heard some people have no problems, other people have nothing but problems (like me)
Im saving up for SK stuff, This is is what SydneyKid said
"The issue with Cefi's (like Silvias) is that they have MacPherson strut front ends, and Bilstein don't make a full replacement strut. However they do make an insert which fits into the standard strut leg.
Bilstein shocks with Bilstein coil over conversions (hardened alloy threaded sleave and top & bottom spring seats) and Eibach (the best) springs. "
Does come at a price though, just over 2K so is fair bit expensive compared to the usual cheap coilovers but I dont want a super low car for the cops to pick on, nor do I want super hard spings that I get shakend up while I drive. I want good handling and everyone knows thats not the lowest or hardest.
Basicly you get what you pay for....
depends on spring rates and how good the shocks are.
i had jap coilovers before and i found them too hard 8k from 6k rear i got the sk stuff and swapped rear springs to front and gots some new eibach springs for the rear (4k) and bilstein inserts in the front and new struts for the rear (bilstein) ....so much nicer to drive around on now
wat type of s13 Tein coilovers were they?coz there different ones aint there?
unless ur talking about da latest new 1's
dam even air borne so i'm guessing ur stock suspension wud have been better
No idea what type they were. Maybe this will help....http://members.iinet.net.au/~pjosephs/cusco/
No thats not my car, thats the car/guy I bought it off.
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
