Hi Fellas
I'm going to upgrade my GTST to a GTR this year so I want to get rid of my GTST. No rush to sell. Is more expensive, however its almost assumed once u buy the stock car you will spend another 10k at least over the next year, go look at Forced Induction Performance for all the people who now want more power form their GTST.
Car is my weekend car. Garaged at my home in my second lock up twin garage. I do all the minor services and all major work has been done by RevZone in Nunawadding. I have added up the invoices for the mods and it comes to about 25k.
The numbers are quite good for a RWD and stock internals. WIth a new turbo and upgraded internals u have all the bits to head into mid 350+ range...just its too crazy on the street for me.
I would consider a swap and cash for a decent GTR...just doubt a GTR owner wants to go back :woot:
All normal things like RWC, tyre tread etc is not an issue. I have had this car for 1 year and only done about 8000km. Most bits have only been on for 4000km or less.
Have to say its fun to drive...and will be for some time cos it will be hard to sell. Might have to seel all bits indiv. and sell the stock bits later on.
Car Details
94 GTST
KM 118,000
RWC etc
No issues with anything
Paint job in excellent condition
Car is only driven on weekends and stored on my garage (lockup)
All mods you need already performed.
Modifications
Custom Spec Hi-Flow Turbo (APS) good for 1.3 bar (which is what its runs now)
550cc SARD Injectors
Spitfire Coilpacks
Bosch 040 Fuel Pump
VG30 AFM
XI series 7 rated NGK plugs
Unifilter Pod and box and/or stock box with Trust panel filter
600x300 FMIC - gktech
Apexi Dump pipe
730CFM metal cat
Twin Cannon Zorst
Bilstien Shockers (as in SKs GB) with King Springs ( can be lowered more if you like)
WORK XT7 18x9.5 rear and 18x8.5 front - metal finish rims (coating done for me by WORK)
Handcook 104s 265s on the back
Endless pads + stock rotors and calipers
Apexi PowerFC
Apexi AVCR
Custom Front Bar
GTR rear wing
Exedy Twin PLate Clutch - button.
Runs Redline Diff/GB and Engine oil. If perform oil analysis on the car which shows it in tip-top shape.
Performance
1/4 - ~12.5s
Power - ~270rwkw
1.3bar @ around 3200rpm...very responsive...very quick on the street.
Price
Not really sure what its worth. The mods equate to around 25k including labour. I'm looking for around $20,000 mark. No rush to sell.
Pics
post-27030-1170454203.jpgpost-27030-1170454213.jpgpost-27030-1170454225.jpgpost-27030-1170454245.jpgpost-27030-1170555785.jpg
hey its kris on berins user name y u sellin all of a sudden r the ninjas after u haha need a bit of a change lol
this car is incredible, extremely clean and well looked after, wit the power to bak it up best of luck wit the sale
hey kris...
yeah thanks. Yeah those ninjas...haha
Not really sure if I want to selll it or not, thought I would put it up and see what happened over time...a few months. Its pretty exp. probably just keep it cos the other half cracked it when i told her I wanted a GTR :no: haha
Actually looking at a new grill for it...looking at chopping one up and going a bit custom cos all the others just dont fit I have found - hence why it has the stock one...some guys in melb helping me atm.
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
