Guest RedLineGTR
soarers are highly made in auto form, cos of it's nature to be a luxury car, there are manual but are reasonably rare, but you can get them one in every five or so. keep looking dont be in too much of a hurry, you'll find a manual just takes time a importer get them to track one down for ya. Hope it helps.
https://www.sau.com.au/forums/topic/15468-is-it-me-or/#findComment-316234
Most soarers are autos due to the fact that they market it to different groups of ppl. The 3.0L non turbo and the 4.0L V8 ones are almost 100% manuals. Hardly any executive in Jpn would want a manual in the upmarket version. You might be lucky to find a manual for the 2.5L turbo version.
But there is a manual twin turbo soarer out there if you really patience, and wait, and look around very hard.... but be mindful that owning a manual soarer can be a pain as parts for manual gearbox can be very hard to find if you ever stuff your box. So you gotta treat your car with respect.
https://www.sau.com.au/forums/topic/15468-is-it-me-or/#findComment-316236
definitely cruise mobiles, get a nice subtle kit for it, updated front lights or whatever they did for the later models, drop it so you can't drive over a piece of paper, 18inch rims... you're ready for a night out on the town! :)
but depends on what ur after, it it's just to cruise, maybe get one. But after performance and handling, look skyward :)
https://www.sau.com.au/forums/topic/15468-is-it-me-or/#findComment-316621
dont listen to what they say soarers r cool.. hehe.. but yes,, its something like 1 in every 500 are manaul.. so keep looking.
here is mine - its got full trust zorst, kit and mags and it goes well. its auto but still fun. It smokes the tires up if your not careful. if i put my foot flat off the lights, i get about 25m of burnout lines.. so have to be careful :)
https://www.sau.com.au/forums/topic/15468-is-it-me-or/#findComment-316753
    • What does it look like with highway driving? And yes, I had a similar thought as Duncan. It looks quite similar in my Stagea and I have made myself accept it as normal. Might have to look into it some day
    • While I was waiting for the new parts to come in for the charge pipe and radiator I decided to do some turbo modification. The drive pressure (exhaust backpressure) was a lot higher that I thought it should be. For 32lbs of boost drive was 55lbs. The turbine housing is a 1.10AR and my turbo builder has suggested to go to a 1.25AR. To test if a larger AR would do anything to reduce drive pressure AND not spend any money I decided to hog out the divider in my current housing. I removed it from the inlet and the whole way through the housing.  After reassembly and testing it doesn't look like this modification did anything for reducing drive pressure or requiring more fuel (making more power). Oh well, it was worth a shot. We'll get some data at the track if it makes it past the 60ft. I also machined a $7 shift knob off Amazon to fit my Stillway shifter since I didn't like the Stillway shift knob. Next on the list was the radiator replacement and fabrication of a new intercooler tube that had no silicon coupler. No pictures of this - I was short on time each night after work to get this done and didn't stop to take pictures.  Next was to get the clutch disks out and replaced. Previously when installing the dogbox I had ordered a set of the same sintered iron disks I had been running because I switched to the 26-spline input shaft. I thought it was odd that they didn't have any markings or brand name on them like all my old disks had but installed them anyway. At the track I could not get the clutch to lock up using my normal strategies. After two track nights I reached out to the clutch manufacturer and ask their thoughts. They said they had to switch the material out because they were having trouble getting the original material and that this new material would not take to being slipped very well.  So out with the first set of 26-spline disks and in with the correct material 26-spline disks. While I had the trans out I added an inspection/service hole. I've wanted one of these for a while. Now I can have a look at things and change the front cover shimming when needed (clutch wear). I hustled and got the clutch change done in a few hours on a Saturday. Hopped in the car and drove home. On the way home I did a 1-3 pull. When shifting from 2nd to 3rd the core plug in the back of the cylinder head popped out and dumped all the coolant. Thankfully I was only 30 seconds from home and coasted it there. Datalog showed nothing unusual and 2.5psi of coolant pressure. That plug has been in there since 1992 but I guess it worked its way out. Pulled the trans AGAIN and replaced the plug, JB welded it in, and made a brace. Also deleted the head drain I had added in during the bearing issue fiasco.  I am currently changing my boost control plumbing to make it cleaner. After that is done I'll make another attempt at getting past the 60.
    • Are you 100% sure this isn't tune related?
    • 140-150 across the board. At this point hoping the grounding harness fixes it. My grounds are all tied to the chassis and none to the battery. For SR and KA that’s never been a problem for me but had a few other guys here and Reddit who told me RB really like a very solid ground setup tied to the battery so going to try that next, I’m stumped if that doesn’t do it. Never had a car have spark and fuel and not fire off before. Only thing I can think is the spark is intermittent/weak because of grounds nothing else really makes sense at this point
    • I am having close to the same issue. Can you help me with what wire you grounded to get your pump to trigger?
