mate it wasnt about urs. Read all the posts and u will see its the dyno posted.
Either way...I think urs (and mine) is Calculated fly wheel torque as the long winded posts above explain...lol.
was fun, i learned something. so chill out.
Yeah sorry I just got that looking over again.... is some good info here. Mine was 440nm @ hubs, no TCF for trans loss so its effectively whatever the amount of torque the engine is making less whatever it lost going through the tranmission. I'd assume yours is the same as well.
bloody victorians....
i assume your talking about my Dyno graph.
Have another look champ..
on the left is KW which is the high two lines which on the left reads 299 kws.
on the right is torque which is the two middle lines which read around 500 nm
cheers
Edited by dangerman4
cheers
yes I think we know that now...that whats happens when u drink and read. Anyway its all good now.
So it seems that chassis dynos are giving rough flywheel torque figures, but including drive train losses. Does that seem a little odd and round about to anyone else?
Any idea why they would do something like this? Giving rear wheel torque figures will give much higher numbers and look more impressive :blink: and actually be more accurate as there are no assumptions (except maybe tyre size, but this could be entered)
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
