Hi all
I've just installed a Power FC pro (RB251PRO) for my R33 GTST. it's the correct model as far as I can tell.
The hand commander fires up and doesnt hang or anything. There are no errors in the sensor screen. I've turned the boost controller off in the HC.
When I switch to ignition, my fuel pump doesnt prime, and if i crank it it doesnt fire. Replacing it with the stock ECU and fuel pump primes, and it fires up.
Anyone have any ideas ? I'd be really gutted if i cant use this ECU :)
https://www.sau.com.au/forums/topic/154721-car-wont-start-with-powerfc-pro/
i had a look at mine just now... i dont have the F/P light greyed out until i start the engine... also, the O2H light on mine isnt greyed out either.
i think the pic from the faq is when the engine has started..
i dont no if this is a good or bad idea.. but i did it when i had some fuel pump issues recently, she wouldnt prime etc.. i dont wana see any tears if anything blows up or something though :)
i grounded the neg wire (blue wire if i recall correctly) on the fuel pump connector in the boot and it seemed to bypass the ecu controlling it and make it work :P It was like doing that mod people do to make it run at full voltage or woteva.
could it be a dodgy ground or power feed? and maybe the powerfc is more sensitive to it than the stock ecu ? :S
yes. i've seen this a lot of times. the PFC seems much more sensitve to a good power feed and good earth than the stock ecu. so check your power feed to the ECU, and maybe check your grounds too. or even tee in another ground and run it to a suitable spot.
well, i just spoke to the guy that sold me it. He had it in his 200SX with rb25det dropped in, and he says he had his fuel pump hard wired into the ignition, just as above!
however, I'm just wondering if there is an option perhaps to make the PFC disable/enable the fuel pump control as it seems a bit odd still.
its no different to the normal powerfc so just debug as if it were a normal PFC
can you post up what your sensor / sw check looks like?
did you do factory reset?
any of the sensor names in BLACK highlight (in sensor sw check)
do any switches (in sensor sw check) turn on (black dot) if you try and crank it ?
I will take a pic of the screen when I try it again today. I'm going to a friends to go over my ecu loom to check the power and grounding.
I did do a factory reset, and i then turned off the boost control. I checked the AFM type and it is set to normal.
none of the names were highlighted in black in the sensor sw check.
Right,
the fuel pump sensor changes to a black dot in the sensor screen when you try to start the car, so it must think that it is activating the fuel pump (but it isnt).
today I grounded the fuel pump so it always pumping when the ignition is on, and the car started. So this means that the fuel pump circuit in the PFC is faulty?
I let it idle for 10 mins, then 10 mins with rear window heater on, then 10 mins with A/C on. However now when i start it up, it sometimes hunts for a few seconds, and also the idle is high (1100rpm). If I drop the clutch and let the revs drop while driving they take a while to go below 1100rpm, and if changing up this can sometimes pull the car forward, so isnt ideal. I can get used to it but maybe someone knows a solution?
would anyone know where the resistors etc are for the fuel circuit on the pfc? I opened it up and the PCB looks fine, no burnt tracks or anything.
finally, will i do any harm running the fuel pump like this. It is an R34 GTR fuel pump, and is 2 stage. It is quite loud anyway, but on idle it used to drop to lower pressure and was a little quieter. Now it is is runing high pressure constantly, will this do any harm?
cheers
adam
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
