It would have to be a GTS4 RB20 to allow the AWD to remain.
Or a Stagea RB25 for the same reason.
You can pick up RB20 AWD block and GB for $2000 and was quoted $ 2500 for a Stag RB25 a while ago.
Is it just a filler while you get the RB26 built?
https://www.sau.com.au/forums/topic/154751-rb20-in-gtr/#findComment-2878068
guys
the person who posted up this thread has gone through heaps of problems with his engine lately....he has had dramas with all different workshops with his Rb26...
he asked a question, so if you dont have anything nice to say, dont say it. he just needs the info.
https://www.sau.com.au/forums/topic/154751-rb20-in-gtr/#findComment-2878335
guys
thanks for that..
I expected comments like this but they dont know whats going on.
https://www.sau.com.au/forums/topic/154751-rb20-in-gtr/#findComment-2879014
ahh ok, so it would have to remain 4wd?
basically just going through options to get the car back on the road.
https://www.sau.com.au/forums/topic/154751-rb20-in-gtr/#findComment-2879017
my guess is your 'GTR' is 4wd so yes, what ever motor you fit, will still retain the 4wd setup. you can either fit an RB20 from a R32 GTS-4 or an RB25DET from a Stagea. Either motor will drop straight into the R32 bay quite easily.
Edited by _8OO5TED_
https://www.sau.com.au/forums/topic/154751-rb20-in-gtr/#findComment-2879085
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
