hmmm. i bet it was making a nice wir wir wir wir noise yes?
the corect tension is no slack. oh eay way to check is by flapping it like you do a rubberband. if it makes a audible twang. its to tight.
if it makes a thud its just right :thumbsup:
  • Replies 57
yes it whirred nicely
and it didnt twang when flicked when we did it
if it makes a thud its just right :huh:
ahh subjective. :thumbsup:
I setup mine with the correct tension as per the engine manual. It had slight slack but was not loose. It had tension if that makes sense. :laugh:
My initial feeling was... It should be slightly tighter. But its not supposed to be 'tight'.
Like me,try to move forward.If finances are ok then rip the head off and check damage.If pistons are ok then perhaps a port clean and even cams.Otherwise locate a standard head and bolt her back together.Do you feel you could rebuild it yourself if pistons are gone?
considering im unemployed im not ripping it apart unless i gotta, comp test it is as B|4cK32 said
gates high performance ones HRthirtyone?
Edited by Rednisr31
yea dude, the blue ones, that are meant to be 3x stronger etc.
if you dont have cash to fix it straight away, park it up , and take the head off..... Dont even bother with a compression test, you should have bent valves. it wont hurt to take it apart and suss the damage.
should, ya never know tho i might just be lucky
my mate was smashing limiter with his rb30e and snapped a timing belt and it didn't damage it internally
I think rb30e are considered not interference engines, meaning the valves can neve rhit the pistons.
In a rb25 howver i believe ther are a interference engine so yes the valves will smash the tops of pistons.
Hope fully im wrong.
Sorry to see that happen.
the following was taken from the service manual for r33 gts25t.
"6. Adjust timing belt tension.
(1) Turn the crankshaft clockwise twice with the tensioner pulley
installation bolt in loose position.
(2) Insert wrench to tensioner pulley hexagonal hole to fix the tensioner
pulley to tighten the installation bolts.
Tightening torque (N-m{kg-m}) 43-58 {4.4-5.9}
*The timing belt tension should be at correct tension"
Ouch thats nasty and making me freak out a little bit.
I had a Gates belt fitted a couple thousand kms ago and it whirrs very loudly. The belt cover is off and I dont think I could get 10mm play in it.
The mech that fitted it said it will loosen up after a thousand or so kays and that the whirring noise is perfectly normal. Will I have to do the whole belt replacement procedure i.e timing etc to loosen it or can I safely just loosen it off a little bit with it all in place?
I have never done it myself before hence I dont know how the tensioner operates.
to adjust the tensioner u need the bottom timing cover off which means u need the fan off and radiator out and harmonic balancer off as well, so pretty much the whole lot (and top timing cover but u say its already off). its not hard to do a timing belt and i cant see how people make it out to be a difficult job. i can get the car from running to belt off and new one on and runnning again in about an hour and a half or less. ive done mine about 20 times though when we been doin the valve shim clearances for the big cams i got.
oh and no the belt doesnt actually need to be removed only the tensioner loosened abit with belt in place.
just make sure the 3 dots line up and u will have no problems for anyone attempting the belt change themselves :laugh:
Edited by CruiseLiner
rb30s are interference engines
    • That still isn't a lot to go on. I don't have a Y50 Fuga Head Unit wiring diagram. I can say that a lot of nissans of that age shared head unit plugs, so if you are in Australia something like this would probably help: https://aerpro.com/app091# You plug that into the car loom, then either plug the head unit ISO into that (if it has ISO), or you buy and ISO adapter harness that you wire in. Bit of stuffing around, but once you have ISO its easy to change things in future.
    • It is a kunfine Android screen . Does anyone know the wirering diagram of the fuga ??
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
