Just looking into buying an Eboost2 controller and some new gauges.
I've hit a wall deciding whether to get a boost gauge or not as Im not sure whether or not the Turbosmart Eboost2 controller has an actual boost gauge within its display. As I obviously dont want to have a separate auto meter boost gauge next to my eboost displaying the same info when i could have a voltmeter or another gauge etc. And I need to buy them at the same time as I am making a custom panel to mount them in my dash for a factory look.
So my question is, to anyone that knows or has an Eboost controller, does it have a boost gauge which stays on while your driving, working like a digital boost gauge? Or does it just tell you what the boost is set at?
I have tried ringing a few autobarn stores which sell them but nobody seems to know what they are on about, just giving me ummms and aaaahhhs.
https://www.sau.com.au/forums/topic/155067-eboost2/
This might help you a little if you already havn't checked it out, it gives you downloads of instructions which should give you some insight...
http://www.turbosmart.com.au/index.php?id=42
Yeh i had tried that before originally posting, the PDF files are corrupted and wont open.
https://www.sau.com.au/forums/topic/155067-eboost2/#findComment-2885027
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
    • Neg, the top one is actually for the front. The sizes are 18x10.5 +18 and 18x11 +32.   I measured many times but I'm sure I'll have problems as this is the thread for problems.
