am after everyones opinions on running a D-Jetro,
currently have Rb26 forged internals, T04Z on 24Psi, 260 9.15 poncams, 044 sard 800cc etc
and am running a power fc with stock afmeters, seeing 416.9kw at the wheels
i want to get rid of the Afmeters as they are restricting the power.
can i just get the map sensors, loom and nipples and fit up and still keep my power fc that is in the car at the moment????
want to get my 10second pass, but want to get the best 10 second pass i can cause i only get 1 go at it.
if i get under a 10.9 they will more than likely not let me race again until roll cage etc.
all help and advice appreciated.
Cheers
Jez
https://www.sau.com.au/forums/topic/155099-power-fc-d-jetro/
covered in detail in the powerfc faq, its in my sig
have a read of it, covers pro's and con's of ljetro and djetro setup
no you cant just buy map's and splice them into your normal powerfc
and no they wont be a restriction, you will just be hitting the ceiling value for the current pair of afms. upgrade to larger will solve that
yeah man the only restriction would be the resolution of the 32 gtr AFM's if you upgrade them both to Z32's then there will be no difference.. if anything looking at your setup you got 2 x AFM's on the one 4" inlet on the turbo so your running at least 5" of flow for a 4" turbo or more
thanks fella's ill read the faq now,
yeah i was looking at the z32's but then i thought of getting rid of them, maybe an autronic, was just weighing up some options.
seems like z32's will be the go,
then i can put in some c16 and up the boost to about 28psi :( should see some good numbers
How do I hook up the D-Jetro Map Sensor Harness Kit?
There are various installation methods for the Djetro Map Sensor depending on the Car Model. For example Evo Lancer CT9A do not have to do anything as the car runs a factory Map Sensor. Skyline RB26 customers must splice twin Map sensor into the Airflow meter harness wiring. Nissan S15 customers must also manually splice a single Map Sensor into the harness. Below are instructions on how Skyline RB26 customers should connect up the Djetro kit.
It appears that D-jetro customers must splice the twin map sensors into the Boost Control Kit harness (or at least use the sme port) to extract positive and negative power.
The signal for each MAP sensor is then connected to Cylinders #3 and #4 based on the Apexi diagram below
is this only if you have the special power fc?
    • I found a supplier for an arm in NZ. https://thrashgaragenz.com/products/nissan-skyline-v35-z33-350z-front-lower-straight-arm-rh-side?srsltid=AfmBOopMdfCFDc_8yVZZ9kq5nIngPHRTBzUU8v4SAptJaRO52Wjs0bC6 I looked closely at the photo of that one and the Z1 arm, and it's the same bloody arm. Scratches all match in the photo 😂 How hard is it to change that joint? Also they seem to be listing two options https://thrashgaragenz.com/products/nissan-skyline-v35-z33-350z-front-lower-straight-arm-balljoint-rh-side?_pos=1&_sid=229acde44&_ss=r And now I have no idea what size I'd need yay
    • Ill review it again, from memory when I first saw some of Trailer Park Boys I wasn't a huge fan. I ended up at Letter Kenny after watching Shoresy, which is a bit ass backward, ha ha
    • "lol dunno" either But like you, I can't see any reason they would need to be different LHD to RHD
    • I agree with you WRT the hard top. MX5's may be one of the better looking soft tops but I cannot think of ANY car, EVER that looks better with a soft top vs a hard top (or a designed roof). At all, ever. I also feel this way about the C5 Vette, the Z06 looks horrible compared to it's original form, it has an exaggerated version of the differences you're talking about.
    • Hey crew, Failed my WOF cause of a lower control arm, and I've decided to hit both arms, and also the compression rods at the same time(seems they're gonna be the most likely upcoming failure points from some discussions with the lads over on the G35 reddit). I've looking at these form Z1:  https://www.z1motorsports.com/front-suspension/hayaku-automotive/hayaku-g35-front-compression-rod-p-40716.html https://www.z1motorsports.com/front-suspension/hayaku-automotive/hayaku-g35-front-lower-control-arm-p-40674.html I asked Z1 if they'd work as it's the same platform, just RHD vs LHD. I basically got told "Lol dunno". Specifically they aren't aware of any difference but can't guarantee fitment as they haven't done it on a 350GT. So guess I'm asking is if there is any issues with using 2005 G35 coupe suspension parts on a 2005 350GT coupe? Orginally I thought it could be something in the way of the arms that each control arm is designed to be positioned around, but that'd be an engineering nightmare for Nissan needing two different shaped control arms 😅
