am after everyones opinions on running a D-Jetro,
currently have Rb26 forged internals, T04Z on 24Psi, 260 9.15 poncams, 044 sard 800cc etc
and am running a power fc with stock afmeters, seeing 416.9kw at the wheels
i want to get rid of the Afmeters as they are restricting the power.
can i just get the map sensors, loom and nipples and fit up and still keep my power fc that is in the car at the moment????
want to get my 10second pass, but want to get the best 10 second pass i can cause i only get 1 go at it.
if i get under a 10.9 they will more than likely not let me race again until roll cage etc.
all help and advice appreciated.
Cheers
Jez
https://www.sau.com.au/forums/topic/155099-power-fc-d-jetro/
covered in detail in the powerfc faq, its in my sig
have a read of it, covers pro's and con's of ljetro and djetro setup
no you cant just buy map's and splice them into your normal powerfc
and no they wont be a restriction, you will just be hitting the ceiling value for the current pair of afms. upgrade to larger will solve that
yeah man the only restriction would be the resolution of the 32 gtr AFM's if you upgrade them both to Z32's then there will be no difference.. if anything looking at your setup you got 2 x AFM's on the one 4" inlet on the turbo so your running at least 5" of flow for a 4" turbo or more
thanks fella's ill read the faq now,
yeah i was looking at the z32's but then i thought of getting rid of them, maybe an autronic, was just weighing up some options.
seems like z32's will be the go,
then i can put in some c16 and up the boost to about 28psi :( should see some good numbers
How do I hook up the D-Jetro Map Sensor Harness Kit?
There are various installation methods for the Djetro Map Sensor depending on the Car Model. For example Evo Lancer CT9A do not have to do anything as the car runs a factory Map Sensor. Skyline RB26 customers must splice twin Map sensor into the Airflow meter harness wiring. Nissan S15 customers must also manually splice a single Map Sensor into the harness. Below are instructions on how Skyline RB26 customers should connect up the Djetro kit.
It appears that D-jetro customers must splice the twin map sensors into the Boost Control Kit harness (or at least use the sme port) to extract positive and negative power.
The signal for each MAP sensor is then connected to Cylinders #3 and #4 based on the Apexi diagram below
is this only if you have the special power fc?
    • Ok i will get those 310mm. I found one but on a different site. This is the description on those...is it ok? Technical parameters: - Axle: front. - Disc type: ventilated. - Number of holes: 5. - Disc diameter: 310mm. - Total height with center: 54mm. - Thickness (new/min.): 30/28mm. - Designed for brake calipers manufacturer: Sumitomo.
    • You Gregged a whole racetrack!?
    • Look for broken wire or bad connector at the motor. Might not be it, but is worth starting there, as it is easy.
    • Hi everyone, I’m having an issue with my R32 GT-R. Sometimes, when the car goes over a bump or experiences some vibration, the 4WD warning light comes on the dashboard. When I check the code from the control unit in the trunk, it shows Code 19 – ETS Motor. However, everything seems to be working fine — if I turn off the engine and restart the car, the light goes away and everything functions normally. Has anyone experienced this before? Where should I start troubleshooting this issue? Thanks in advance!
    • I'm back from the dyno - again! I went looking for someone who knew LS's and had a roller dyno, to see how it shaped up compared to everything else and confirm the powerband really is peaking where Mr Mamo says it should. TLDR: The dyno result I got this time definitely had the shape of how it feels on the road and finally 'makes sense'. Also we had a bit more time to play with timing on the dyno, it turns out the common practice in LS is to lower the timing around peak torque and restore it to max after. So given a car was on the dyno and mostly dialled in already, it was time for tweaking. Luis at APS is definitely knowledgable when it came to this and had overlays ready to go and was happy to share. If you map out your cylinder airmass you start seeing graphs that look a LOT like the engine's torque curve. The good thing also is if you map out your timing curve when you're avoiding knock... this curve very much looks like the inverse of the airmass curve. The result? Well it's another 10.7kw/14hp kw from where I drove it in at. Pretty much everywhere, too. As to how much this car actually makes in Hub Dyno numbers, American Dyno numbers, or Mainline dyno numbers, I say I don't know and it's gone up ~25kw since I started tinkering lol. It IS interesting how the shorter ratio gears I have aren't scaled right on this dyno - 6840RPM is 199KMH, not 175KMH. I have also seen other printouts here with cars with less mods at much higher "kmh" for their RPM due Commodores having 3.45's or longer (!) rear diff ratios maxing out 4th gear which is the 1:1 gear on the T56. Does this matter? No, not really. The real answer is go to the strip and see what it traps, but: I guess I should have gone last Sunday...
